Received lynx level 4 issue
Post Date: 2020-12-21
gaborik31 View Drop Down
  Quote gaborik31 Quote  Post ReplyReply bullet Topic: Received lynx level 4 issue
    Posted: 21 Dec 2020 at 1:00pm
Hello,
I received the lynx level 4 last night and after about 2 hours of gaming the GPU is seemingly dying? I'm not sure if that's the case, but just from what I've read online that seems to be what they point to with the issues I'll describe.
So essentially I was playing for a bout 2 hours with no issues then all of a sudden freeze into crash. During the crash the screen went static like black/white you would see from an old TV type of static. I had only played one game when all this happen so I'm not sure what would've been the case on a different game, but now everygame I've tried has terrible artifacting and specks of what look like static? all over the screen. The computer seemingly works fine to browse the internet watch videos or do whatever at least at the moment. However, as soon a game starts it all goes bad.
I've reinstalled the driver, reverted the driver to previous version, reinstalled windows, reset the bios to default(said no changes made so I don't know if lynx level 4 comes with any bios changes). I just don't know anymore I've waited a while to receive it just to be met with this. I've tried everything I could find on the internet every setting tweak in the Radeon software people online said worked for them, but nothing. I understand something could've happened during shipping maybe something got out of place, but it worked for so well for the few hours when I first started then all of a sudden it just went.
Gewd View Drop Down
  Quote Gewd Quote  Post ReplyReply bullet Posted: 21 Dec 2020 at 1:15pm
Reseat the graphics card.
Config ID 3646575 | Stg 1 11/18/20 | Stg 2 12/8/20 | Stg 3 12/15/20 | Stg 4 12/15/20 | Stg 5 12/16/2020 | Stg 6 12/18/2020 | Stg 7 12/18/2020 | Order Shipped 12/21/2020
  Quote gaborik31 Quote  Post ReplyReply bullet Posted: 21 Dec 2020 at 2:44pm
I've reseated. Still same issue.
adambomb13 View Drop Down
  Quote adambomb13 Quote  Post ReplyReply bullet Posted: 21 Dec 2020 at 2:49pm
What is the temps of the GPU?
Config ID 3536215- Stg 1 11/13 to 1/4 / Stg 2 as of 1/5 to 1/11 / Stg 3 as of 1/11 / Stg 4 as of 1/11 / Stg 5 as of 1/11 to 1/15 / Stg 6 as of 1/15 / STG 7 shipped 1/18, received 1/26 (5950X,3090)
  Quote gaborik31 Quote  Post ReplyReply bullet Posted: 21 Dec 2020 at 2:54pm
It gets to like 55 degrees on csgo at like 90% usage. 0% usage its around 33 degrees
  Quote adambomb13 Quote  Post ReplyReply bullet Posted: 21 Dec 2020 at 3:06pm
Im just thinking out loud, So bare with my hungover thought process:
55 degrees is pretty awesome so I doubt its heat issues
Try a different video cable?
Try a different video out port on the back of the video card?
Some monitors have multiple input ports, try a different one?
Try to un-install/re-install monitor driver in device manager
Edited by adambomb13 - 21 Dec 2020 at 3:08pm
  Quote gaborik31 Quote  Post ReplyReply bullet Posted: 21 Dec 2020 at 4:10pm
Tried new cable, new monitor, drivers. Only one video port on back of card the video cables I have at the moment. Not sure what's even left to do even when DS does reach out.
Gewd View Drop Down
  Quote Gewd Quote  Post ReplyReply bullet Posted: 21 Dec 2020 at 4:40pm
See if they will sent you a new graphics card. Problem is, you can send it back to them and they’ll probably replace for free. But you’ll be waiting forever
  Quote adambomb13 Quote  Post ReplyReply bullet Posted: 21 Dec 2020 at 4:48pm
You mentioned that you re-installed Windows, Did you do a fresh install? (deleting everything). Im asking because I ran across this utility DDU (Display Driver Uninstaller) that really really un-installs video driver(s) completely.
https://www.guru3d.com/files-details/display-driver-uninstaller-download.html
  Quote gaborik31 Quote  Post ReplyReply bullet Posted: 21 Dec 2020 at 6:12pm
Yeah hoping not to send it back, but if it doesn't work and that's the only way no option. And I've done the driver uninstall through DDU.. still same issues.
  Quote adambomb13 Quote  Post ReplyReply bullet Posted: 21 Dec 2020 at 6:18pm
UGH, Try a different PCIE slot on the motherboard to verify if its the GPU or motherboard.
My last suggestion sorry
  Quote gaborik31 Quote  Post ReplyReply bullet Posted: 21 Dec 2020 at 6:37pm
Yeah no worries. Thanks for the suggestions. Still nothing from DS yet sooo
  Quote gaborik31 Quote  Post ReplyReply bullet Posted: 21 Dec 2020 at 8:51pm
Just an update for anyone who cares... Swapped out the card with my old old GTX 970 and all games running flawlessly. So yeah seems it was a dead gpu just 3 hours after my initial set up. Pretty crazy considering all the stress testing and QA but things happened I suppose. I will update with what happens with support.
Edit: Would've done this sooner, but completely slipped my mind I had this pc still laying around.
Edited by gaborik31 - 21 Dec 2020 at 8:58pm
Nomad1970 View Drop Down
  Quote Nomad1970 Quote  Post ReplyReply bullet Posted: 21 Dec 2020 at 9:11pm
Unfortunately with electronics things just happen. My first DS computer worked just fine for about 3 months and then started crashing for no real reason. After a bit of trouble shooting it was a bad memory card. DS replaced all 4 of them and never had a problem with them for 5+ years until I updated my computer.
My Precious 2
I7-9700 oc 4.7GHz
SSD M.2 1TB Samsung 970 EVO
240GB Samsung 860 Pro SSD
1TB W.D. HD
EVGA GTX 1080Ti
  Quote Cretae Quote  Post ReplyReply bullet Posted: 22 Dec 2020 at 5:10am
[email protected]    May help you expedite.
About what Gewd said, there shouldn't be much delay as the Lynx 4 GPUs are not known to be in short supply.
Sorry for the trouble, but electronic parts do stuff like this.
  Quote gaborik31 Quote  Post ReplyReply bullet Posted: 22 Dec 2020 at 11:58am
Update: Spoke with DS. They're sending me a new GPU.
  Quote adambomb13 Quote  Post ReplyReply bullet Posted: 22 Dec 2020 at 12:53pm
Awesome, hopefully overnighting it :)
Gewd View Drop Down
  Quote Gewd Quote  Post ReplyReply bullet Posted: 22 Dec 2020 at 1:00pm
Grats!
  Quote Cretae Quote  Post ReplyReply bullet Posted: 23 Dec 2020 at 4:45am
  Quote hoserator Quote  Post ReplyReply bullet Posted: 23 Dec 2020 at 12:43pm
Soon! Awesome
YerBuddy2 View Drop Down
  Quote YerBuddy2 Quote  Post ReplyReply bullet Posted: 26 Dec 2020 at 8:52am
I like to read stuff like this. Awesome support from DS and from you guys in the forum. Reading this helped make my decision to order a new computer.
  Quote Cretae Quote  Post ReplyReply bullet Posted: 26 Dec 2020 at 2:50pm
  Quote hoserator Quote  Post ReplyReply bullet Posted: 27 Dec 2020 at 10:16pm
Hahaha
And that is precisely why we are here.
Strong
This page was generated in 0.1010742 seconds.
