Remote won't change lighting effects on rgb strip.
Post Date: 2019-09-06
captainfin View Drop Down
  Quote captainfin Quote  Post ReplyReply bullet Topic: Remote won't change lighting effects on rgb strip.
    Posted: 06 Sep 2019 at 2:23pm
Hello I just received my Lumos which came with the rgb lighting strip. I love the system so far however for some reason my remote won't change the lighting effects no matter where I point it at. I know the remote is working and the led strip was on when i first started the system.
scootX View Drop Down
  Quote scootX Quote  Post ReplyReply bullet Posted: 08 Sep 2019 at 12:26pm
My new Lynx system fan lighting & RGB LED strip are not effected by the remote control either. Does anyone know where the IR receiver sensor is located? (I'm guessing on the front of the case, but I can't find it)
  Quote scootX Quote  Post ReplyReply bullet Posted: 09 Sep 2019 at 12:32pm
I checked the CR2025 battery in the remote and it measured ~2.85V - After replacing it the remote works! However, I'd still like some sort of directions on using it! **Also: I only had a CR2032 on hand. Same voltage & diameter but slightly thicker. It slid in no problem.
HockeyBuck View Drop Down
  Quote HockeyBuck Quote  Post ReplyReply bullet Posted: 09 Sep 2019 at 12:45pm
Here you go....
https://www.digitalstorm.com/forums/uploads/8941/DS_RGB-Remote_Control-instruction_sheet.jpg
  Quote scootX Quote  Post ReplyReply bullet Posted: 09 Sep 2019 at 12:53pm
Originally posted by HockeyBuck
Here you go....
Thanks - now if only I can figure out the instructions!
  Quote Cretae Quote  Post ReplyReply bullet Posted: 11 Sep 2019 at 5:55am
Cycle through the over 300 combinations to your heart's content. When you find a scheme you like, this is how you lock it in for when you power off your rig:
Remote Control
MODE -> LOCK -> POWER (OFF) --> POWER (ON)
* above POWER refers to remote power button not system power button
Once I perform those sequences on a power cycle the RGB settings hold.
Hope it works for you!
  Quote scootX Quote  Post ReplyReply bullet Posted: 12 Sep 2019 at 5:17pm
Yes - seems to work. Thanks.
  Quote Cretae Quote  Post ReplyReply bullet Posted: 13 Sep 2019 at 4:53am
Our pleasure.
Jhamby1980 View Drop Down
  Quote Jhamby1980 Quote  Post ReplyReply bullet Posted: 11 Nov 2019 at 6:18pm
Mine didn't come plugged in? Does this go to the mono or the psu?
  Quote Cretae Quote  Post ReplyReply bullet Posted: 12 Nov 2019 at 3:17am
Hmmm, sorry about that. Definitely would plug into the motherboard just like a fan header. See if you find an open receptacle nearby. Be sure you are grounded, and its always a good idea to unplug your system from the wall. After you unplug, press and hold the power on button for several seconds to discharge capacitors on the motherboard. This is all very precautionary, but safe. Good luck.
If you can't figure this out, call DS support and they will walk you through it on the phone.
Bob100 View Drop Down
  Quote Bob100 Quote  Post ReplyReply bullet Posted: 12 Nov 2019 at 3:32pm
Remote Control
________________________
That worked for me as well.
  Quote HockeyBuck Quote  Post ReplyReply bullet Posted: 12 Nov 2019 at 3:43pm
Most RGB light strings should have a small control module box they would plug into on one end.
Toson View Drop Down
  Quote Toson Quote  Post ReplyReply bullet Posted: 01 Jun 2020 at 1:52pm
So much for the QA stage...mine isn't working either so I plan to open up the case soon and see if it's a plugin issue.
