Replacement Pump/Res?
Post Date: 2020-08-11
soccastar001 View Drop Down
  Quote soccastar001 Quote  Post ReplyReply bullet Topic: Replacement Pump/Res?
    Posted: 11 Aug 2020 at 12:05pm
Hey all, my reservoir on my Aventum 3 has cracks in it where the pump screws into the acryllic of the reservoir. There are at least 3 cracks that I can see around the two front screws. It looks like there is space between the reseroir proper and where these screws screw in so it hasn't caused any leaks yet but in my experience once acryllic cracks they keep growing.
So anyway it appears that I need a new reservoir. I was looking into getting my own pump/reservoir combo to replace it but because of the design of the Aventum 3 I don't see a standard place where another pump could be attached.
So my question is do I need to buy a replacement directly from DS? How much are they? Are there any alternatives?
Thanks
  Quote hoserator Quote  Post ReplyReply bullet Posted: 11 Aug 2020 at 5:22pm
You are going to have to cal DS for the brand used on your system.  Also check the EK website. I have an Av II and the res and some hardware was EK.
Once you know the brand you can order from the retailer of your choice.
