Reverse Side Build?
Post Date: 2018-10-01
Phartsniffer View Drop Down
  Quote Phartsniffer Quote  Post ReplyReply bullet Topic: Reverse Side Build?
    Posted: 01 Oct 2018 at 4:19pm
I've noticed that the Aventum X will come with the "show off side" on the right side(from the front). Is it possible to have the computer built on the opposite side, so that the show off side is on the left?
  Quote bprat22 Quote  Post ReplyReply bullet Posted: 01 Oct 2018 at 5:00pm
Never saw them do it, so right side window with inverted motherboard is it. They didn’t design it to select mobo orientation.
