RGB lighting connection help
Post Date: 2023-06-16
slicejones View Drop Down
  Quote slicejones Quote  Post ReplyReply bullet Topic: RGB lighting connection help
    Posted: 16 Jun 2023 at 9:16am
Hi,
I’m trying to get the RGB lighting remote to work. In the pack there’s the remote and 2 cords. The remote works. I can see the red light, but none of the buttons do anything. The light strip works, but is set to white.
Do I need to connect one of the cords to the motherboard to get the remote to work ?
Is that correct ?
If, so, where do I connect the cord. I can see one end possibly connects to the light strip.
On the motherboard, I can see a connector called RGB Header 1 and RGB Header 2.
Do I connect to either one of those or somewhere else ?
Thanks for any help !!
Edited by slicejones - 16 Jun 2023 at 11:38am
  Quote hoserator Quote  Post ReplyReply bullet Posted: 16 Jun 2023 at 4:45pm
The 2 cords are probably spares or extras that were left over after the build. I don't have a remote or lights but some others will post how to work it.
Smile
This page was generated in 1.855469E-02 seconds.
