RGB lights
Post Date: 2018-06-04
Ryandawolf231 View Drop Down
  Quote Ryandawolf231 Quote  Post ReplyReply bullet Topic: RGB lights
    Posted: 04 Jun 2018 at 7:26pm
Hi is there a way to keep the rgb lights inside my computer on after I shut down? thanks.
  Quote bprat22 Quote  Post ReplyReply bullet Posted: 05 Jun 2018 at 1:58am
You’d have to plug the module into an external source.   The power supply in the case shuts down on power off.
  Quote Cretae Quote  Post ReplyReply bullet Posted: 05 Jun 2018 at 7:00am
If you mean how do you keep a particular light selection after you power off your system, this seems to work:
After you pick the lighting you want, on the little remote, press:
MODE > LOCK > (remote) POWER OFF > (remote) POWER ON.
If that's what you wanted, hope it works for you.
