RGB Lights
Post Date: 2022-11-20
CMCCARROLL View Drop Down
  Quote CMCCARROLL Quote  Post ReplyReply bullet Topic: RGB Lights
    Posted: 20 Nov 2022 at 12:45pm
I purchased a Velox with standard rgb lighting.  led strips and fans.   When I set everything to white all my fans (except one) have a greenish brown tiny.  They are not white.  I still have one of the eight fans that is white.
Any way to correct this or am i just going to have to replace the fans.  I want my white lights to actually be white?
Be Curious. Not Judgemental.
db188 View Drop Down
  Quote db188 Quote  Post ReplyReply bullet Posted: 20 Nov 2022 at 6:17pm
any stuck on different colors as well?
 these fans generally work in series, so you can try juggling the order to see if it fixes things, and try to isolate the fan(s) causing the problem.  if you don't you'll never know which one(s) are causing the others not to work.
Edited by db188 - 20 Nov 2022 at 6:21pm
Aventum 3
I7-6700K
Gigabyte G1 Z170X Gaming GT
Corsair Hx1000i 1000W
Gigabyte M28U 4K
This page was generated in 2.441406E-02 seconds.
