Rig has arrived! Have a few questions thoPost Date: 2010-11-05 |
| Author | |
Shockalocka
Joined: 12 Oct 2010 Online Status: Offline Posts: 9 |
Topic: Rig has arrived! Have a few questions thoPosted: 05 Nov 2010 at 5:19pm |
Just received the Hailstorm this morning, and noticed that my stage 6 LC doesn't have a rear radiator as opposed to VideCorSpoon's and Prator's Hailstorm review.
And here is my current config: Chassis Model: Special Deal Hot Seller - Black OPS HailStorm Edition Exterior Finish: - Standard Factory Finish Trim Accents: - Standard Factory Finish Processor: Intel Core i7 950 3.06GHz (Quad Core) Motherboard: ASUS Rampage III Extreme (Intel X58 Chipset) (Features USB 3.0 and SATA 6Gb/s) System Memory: 6GB DDR3 1600MHz Digital Storm Certified Performance Series (Highly Recommended) (Hand Tested) Power Supply: 1000W Corsair (Dual/Triple/Quad SLI Compatible) Expansion Bay: - No Thanks Hard Drive Set 1: Operating System: 1x (40GB Solid State (By: Intel) (Model: X-25V Edition) (Extreme Performance) Set 1 Raid Options: - No Thanks Hard Drive Set 2: Multimedia\Data: 1x (1TB Western Digital Caviar (7200 RPM) (64MB Cache) (Model: Black Edition WD1002FAEX) Hard Drive Set 3: Backup\Misc.: - No Thanks Optical Drive 1: DVD-R/RW/CD-R/RW (DVD Writer 24x / CD-Writer 48x) Optical Drive 2: - No Thanks Internet Access: High Speed Network Port (Supports High-Speed Cable / DSL / Network Connections) Video Card: 2x SLI Dual (NVIDIA GeForce GTX 480 1.5GB (Includes PhysX Technology) Add-on Card: - No Thanks Sound Card: Integrated Motherboard Audio Extreme Cooling: H20: Stage 6: Sub-Zero LCS Dual Loop: CPU & Dual SLI/CrossFire Video Cards Called DS and the tech said the radiator is located inside, which I already knew that, but always thought that the stage 6 has 2 radiators in it's cooling configuration. Can anyone clarify? |
Sarah
Hardcore Gamer Joined: 07 Jun 2008 Online Status: Offline Posts: 879 |
Posted: 05 Nov 2010 at 5:24pm |
There is 2 radiators, they are both inside the case, it is how we are building them now.
Shockalocka
Posted: 05 Nov 2010 at 5:33pm |
Ah okay, thanks for the quick response!
Alex
Joined: 04 Jun 2012 Online Status: Offline Posts: 16314 |
Posted: 05 Nov 2010 at 5:37pm |
You're welcome!
Exactly. This allows us to ensure your system does not get damaged during shipping from the weight of the rear radiator. You can check that the team mounted a second radiator setup at the bottom compartment of the HailStorm.
By the way, this is not a post asking for configuration advice, so I'll be moving it to the 'General Discussion' section. Edited by Alex - 05 Nov 2010 at 6:34pm |
Mortus
Joined: 14 Oct 2010 Online Status: Offline Posts: 16 |
Posted: 10 Nov 2010 at 11:08pm |
ya my new rig just got here today too. i can honestly say im extremely unimpressed. sorry DS i was really looking forward to this new rig but so far, quite a disappointment. ill do a review with pic and what not later. for now though its back to working on.
justin.kerr
Joined: 06 May 2008 Online Status: Offline Posts: 5084 |
Posted: 10 Nov 2010 at 11:22pm |
care to share? did you check your V core?
ablahblah
Joined: 12 Jun 2009 Online Status: Offline Posts: 2312 |
Posted: 10 Nov 2010 at 11:24pm |
details, don't just post something bashing something like that without anything to support it. idc what the topic is, it's just plain rude you know...
R4D4RPR00F
Core i7 920 @ 3.9Ghz Asus Sabertooth X58 EVGA GTX 570 Mushkin 6GB 1414Mhz |
Mortus
Posted: 10 Nov 2010 at 11:36pm |
i said id post later once i can get it running, its not really an issue with the vcore i dont think justin, its just about everything else though, i have yet to get 1 game to run, or the system to reboot clean more then once or twice in a row, overclock errors (just on the first boot, seems ok now *shrug*) NTLDR errors with no boot. hard drives just disappearing mid installs. and so on. i know shipping loosens sone stuff up. this is all after fully checking and re-seating all the sata cables, ram, ect ect. and sorry ablahblah. im usually quite passive and easy going but after month and $7000 id say i have a decent reason to be less then enthused. but again i will apologize. im usually in quite a good mood : ) . ganna mess with it a little more. maybe replace the sata cables and look around the bios a little more. maybe its got something to do with the disappearing act of the HDs in use
justin.kerr
Posted: 10 Nov 2010 at 11:41pm |
Please start a new thread, and post your issues, as much detail as possible.
Have you ran Prime 95? and checked your temps?
wcboltman
Joined: 30 Oct 2010 Online Status: Offline Posts: 173 |
Posted: 11 Nov 2010 at 1:27am |
So you get things straight?
Mortus
Posted: 11 Nov 2010 at 4:36am |
not yet, still quite a few issues to work out. its way too late though. ganna get some sleep and start working on it again in the morning. will update ya tommorow
