RTX 3060 TI is not cutting it - Please advise
Post Date: 2022-05-07
Vitopanchnew View Drop Down
  Quote Vitopanchnew Quote  Post ReplyReply bullet Topic: RTX 3060 TI is not cutting it - Please advise
    Posted: 07 May 2022 at 7:59pm
Hello Folks,
Your guidance will be appreciated. I mistakenly purchased this configuration with the RTX 3060 TI graphics card based upon recommendation, but find it woefully taxed upon use. Here was my explanation of what I do.
" Topic: Buying a new PC - Need advice opinions
    Posted: 02 May 2021 at 3:40pm
Folks,
I have purchased four DS PC's in the past and have been very pleased. The one that I am replacing is a 2009 I7.I wish to spend $2500.00. I will use it primarily for Everquest,an RPG. I will be driving three logons and managing three avatars that way.
For that are not familiar with it it is a 22 year old RPG and is very, very heavy on graphics especially with a hundred or so avatars in the same area.casting spells, etc..and heavy server loads."
I am using one 1080 monitor and the card is in the 90% to 99% range while at rest, meaning, I am not actually moving around but just having the characters standing still.
I need to upgrade to a card that will not be maxed out like this. All of the card advertisements talk in language that I am unable to equate to my needs. Please assist.
Digital Storm Desktop - Config ID 3910666 (Config # 3910666) - Quantity: 1 - Price: $2,763.00
Nomad1970 View Drop Down
  Quote Nomad1970 Quote  Post ReplyReply bullet Posted: 07 May 2022 at 9:01pm
That driver is for an RTX 3050 laptop card. Maybe a driver upgrade will help.
My Precious 2
I7-9700 oc 4.7GHz
SSD M.2 1TB Samsung 970 EVO
240GB Samsung 860 Pro SSD
1TB W.D. HD
EVGA GTX 1080Ti
  Quote Vitopanchnew Quote  Post ReplyReply bullet Posted: 07 May 2022 at 9:35pm
Nomad,
Good catch and appreciated. Why I was packaged with that driver I wonder. Anyways, I just installed the correct driver and the results are the same.
Vito
  Quote Cretae Quote  Post ReplyReply bullet Posted: 08 May 2022 at 4:18am
Just a quick look around, I found multiple posts in/by your game community addressing your issues. I don't get the lingo used, i.e. "boxing", but I bet you do. They seem to recommend turning down specific graphics for specific results. It's not the card, your community says. Here's one specific thread:
https://forums.daybreakgames.com/eq/index.php?threads/poor-performance.275037/
I don't have a clue if this discussion fits you, but I think it's pretty telling that,
"You can have a monster video card and cpu [which I think you do]
and your performance will still take a hit because the game rendering engine sucks for certain things."
VERY good luck with your issue.
Edited by Cretae - 08 May 2022 at 4:21am
  Quote Vitopanchnew Quote  Post ReplyReply bullet Posted: 08 May 2022 at 7:08am
Hello Cretae,
Thank you for responding. Yes, I am familiar with that thread. My concern is that the card seems to be running maxed out. Is it a matter of that the card has only 8GB and I am using it all with multiple sessions? Would I be better served with 12GB in a card like this?
EVGA RTX GEFORCE 3080 FTW3 ULTRA GAMING 12GB GDDR6X
Appreciatively,
Vito
  Quote Onkel_Ken Quote  Post ReplyReply bullet Posted: 08 May 2022 at 3:37pm
I have the EVGA FTW3 Ultra RTX 3080 10GB card and it is very nice. But I agree with Cretae that your issue is most likely not the 3060TI which should have been more than sufficient for decent 1080 performance. I would do more research and perhaps speak with Digital Storm techs before spending a lot of money that may not resolve the underlying problem.
MrCheetah View Drop Down
  Quote MrCheetah Quote  Post ReplyReply bullet Posted: 08 May 2022 at 8:25pm
The VRAM amount appears fine (i.e. using less than a gigabyte on the graphics card). However, the GPU load is probably due to the multiple game instances. From my crash course, there is software to help better manage game resources when (multi-)boxing.
For example, this discussion:
How many EQ Clients are some of you running on a single computer? | Reddit
Excerpt:
Originally posted by Eonan
With a modern processor, loads of RAM, and a program like ISBoxer to help manage the individual client resources...you'd be shocked how many you can run at one. I run 6 and force the FPS for background clients to a minimum of 60 with the main running 90+...with zero issues.
Resources:
Getting Started with Boxing In Everquest | Almar's Guides
ISBoxer
Graphics and performance settings guide | Wiki
P.S. A troubleshooting step would be to look at resource usage while running a single account/session/instance.
Edited by MrCheetah - 08 May 2022 at 8:35pm
  Quote Vitopanchnew Quote  Post ReplyReply bullet Posted: 11 May 2022 at 4:20pm
Thank you everyone. My ignorance is cleared up. I thought that I was overtaxing the card and now I know better.
https://www.pcpartguide.com/is-100-gpu-usage-bad/
  Quote hoserator Quote  Post ReplyReply bullet Posted: 12 May 2022 at 1:21am
Awesome Enjoy.
  Quote Cretae Quote  Post ReplyReply bullet Posted: 12 May 2022 at 4:34am
I hope you get to run your game the way you want to!
