running triple monitors and a single monitor
Post Date: 2021-03-30
Bsowinski View Drop Down
  Quote Bsowinski Quote  Post ReplyReply bullet Topic: running triple monitors and a single monitor
    Posted: 30 Mar 2021 at 4:36pm
I was hoping someone could help me out. I do a lot of sim racing and i just purchased triple monitors. My question is can I run triples on my rig and also a single monitor at my desk for when im not racing and want to work or play other games
  Quote hoserator Quote  Post ReplyReply bullet Posted: 30 Mar 2021 at 11:36pm
Hi,
The NVIDIA Control panel - Set Up Multiple Displays - shows that you choose which monitor to use from a list of available ones and how to configure them. I can't answer your question with practical knowledge but it appears from the language used that you would be able to select the 3 you want for sim racing and only one for the rest at different times. Maybe someone with more knowledge can enlighten us.
Good luck. Smile
Also, as a practical matter, the gpu used for the monitors (deleted) has to have the 4 outputs.
Edited by hoserator - 19 Apr 2021 at 11:10pm
JoeK View Drop Down
  Quote JoeK Quote  Post ReplyReply bullet Posted: 19 Apr 2021 at 4:53am
Depends on your rig honestly
Ordered/Stage 1- 12/11/2021
Stage 2/3- 01/27/2021
Stage 4- 01/28/2021
Stage 5- 01/29/2021
Stage 6/7/Shipped- 02/01/2021
