Safe Temp range for i7 920
Post Date: 2009-08-21
Zurginator View Drop Down
  Quote Zurginator Quote  Post ReplyReply bullet Topic: Safe Temp range for i7 920
    Posted: 21 Aug 2009 at 10:17am
Ok, I'm rolling on a stock clocked i7 right now (due to stock cooling). However, I'm worried- under load, it's hitting 83 C core temp. Is this an ok temperature?
Edited by Zurginator - 21 Aug 2009 at 11:12am
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 21 Aug 2009 at 3:37pm
personally my red line is at 80c but no higher then 83c and you should be fine.
  Quote Alex Quote  Post ReplyReply bullet Posted: 21 Aug 2009 at 4:46pm
If your under 100% stress load, that's fine. Don't forget, your system will never be running under so much stress extensively anyways.
  Quote Zurginator Quote  Post ReplyReply bullet Posted: 21 Aug 2009 at 7:54pm
Ok, thanks guys!
Now to get the money for some LC.... >_<
This page was generated in 2.050781E-02 seconds.
