Safe Temperate Max under Load for i7 920 ?
Post Date: 2009-10-20
Paladin0228 View Drop Down
  Quote Paladin0228 Quote  Post ReplyReply bullet Topic: Safe Temperate Max under Load for i7 920 ?
    Posted: 20 Oct 2009 at 12:28am
So my new DSO system arrived today [ specs at bottom of page ] :
I figured I would see if I could *safely* get a stable OC at 4ghz.. which 6 hours testing on Prime95 + and then a run Linx 0.6.1 seems stable.. However I am getting something around 90c Load temps ( shown with both Real Temp 3.00 and Cpuid Hardware Monitor )
Is it safe to stay at this high of a load ceiling ?
If not, what would be a significantly *better*, yet affordable in-case standard cooling system to look into ( no crazy l2n ideas please :P )
... Keep in mind in January I will be ordering another 6 GB of ram and a second 295x gtx to go into Quad-Sli .. :-)
System -
Processor: Intel Core i7 920 2.66GHz (Quad Core) Factory Overclocked to 3.75GHz
Motherboard: EVGA X58 SLI LE (Chipset: Intel X58)
System Memory: 6GB DDR3 1600MHz Corsair/Mushkin (Digital Storm Certified) (Hand Tested)
Power Supply: 1250W Enermax Galaxy EVO (Dual/Triple/Quad SLI Compatible) (Recommended)
Hard Drive Set 1: Operating System: 1x (1TB Western Digital (7200 RPM) (32MB Cache) (SATA) (Extreme Speed)
Video Card(s): 1x NVIDIA GeForce GTX 295 1.792GB (Includes PhysX Technology)
Sound Card: 7.1 24-bit / 192kHz Decoding High Definition Integrated Audio
Extreme Cooling: H20: Stage 1: Asetek Liquid CPU Cooler
Liquid Color: - Not Applicable, I do not have a H20: Stage 3 Cooling System Selected
CPU Boost: Yes, Factory Overclocked i7 920 from 2.66GHz to 3.75GHz with 100% Stability & Reliability
Windows Boost: Yes, Disable and tweak all of the non-crucial services on the operating system
Priority Build: Ship Within 72-Hours After Order Is Successfully Processed
MISC ADDITION:     RED LED FANS By: James 10/7/2009
hemi392 View Drop Down
  Quote hemi392 Quote  Post ReplyReply bullet Posted: 20 Oct 2009 at 12:35am
seems kinda high probley be safe in the 80c-85c but im not sure on the i7 i got q9650 quad and i only run mine around 70c-75c where 71c is the safe zone on the chip so that extra 5 degress might not hurt you
Asus X79 deluxe w i7-4820k
corsair 750w
Geforce gtx 660sc
Gskill 8gb 1866mhzs ram
signal loop water cooling for cpu
  Quote hemi392 Quote  Post ReplyReply bullet Posted: 20 Oct 2009 at 12:37am
playing a game/ your temps might run a lower anyway
corsair 750w
Geforce gtx 660sc
  Quote hemi392 Quote  Post ReplyReply bullet Posted: 20 Oct 2009 at 12:38am
everyone has thier own heat range they like to run i think.
corsair 750w
Geforce gtx 660sc
  Quote justin.kerr Quote  Post ReplyReply bullet Posted: 20 Oct 2009 at 9:01am
personal preference is one thing, but keeping an i7 under 80C using realtemp is important for stability.
  Use the newest realtemp to, that is an old version.
I have played with many, many overclocks on i7's.  One thing I noticed is that if I intentionally raise the temp, on an overclock that was proven rock solid, it will become unstable, usually starting around 85C. I believe Intels  i7 Tcase max operating temps are 67C so that would be around 79C-82C in realtemp.
90C is just way too hot according to Intel, 90C is way too hot for a long term rock solid machine.
don't get greedy, pushing too far will only reward you with headaches, and extra costs down the road.
If you can't keep an overclock's temps in control, either lower the overclock or upgrade the cooling system.
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 20 Oct 2009 at 2:13pm
ya 85c is limit for me also, I rather stay under 80c.
  Quote Paladin0228 Quote  Post ReplyReply bullet Posted: 21 Oct 2009 at 3:45am
Thanks for the response.
As you said, perhaps I should consider increasing the cooling ?
System as i posted in the top thread has :
HAF 932 case
6 additional Red LED Coolermaster [ i believe ] 120 MM fans ( 2 on the top of case ), 4 on the side.
  Quote justin.kerr Quote  Post ReplyReply bullet Posted: 21 Oct 2009 at 9:39am
well, you have to ask yourself, is it worth $300+ in parts, to raise your overclock some? and/or have better temps?
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 21 Oct 2009 at 11:41am
and for gaming the answer is no, so if with 3.7 you are under 80c then stick with what you got
