Samsung 980 & 990 Pro firmware update?
Post Date: 2023-02-23
JamesAstro View Drop Down
  Quote JamesAstro Quote  Post ReplyReply bullet Topic: Samsung 980 & 990 Pro firmware update?
    Posted: 23 Feb 2023 at 11:44am
What do you think about this article? Should I update my Samsung 980 Pro firmware? I'm nervous about upgrading the firmware on an SSD that my system is currently booting from.
https://www.tomshardware.com/news/samsung-990-pro-firmware-update-released-ssd-health
Hort View Drop Down
  Quote Hort Quote  Post ReplyReply bullet Posted: 23 Feb 2023 at 4:06pm
It shouldn't be a problem. The Samsung Magician software usually makes firmware updates simple. You run the risk of gibber problems later by never updating your firmware.
MrCheetah View Drop Down
  Quote MrCheetah Quote  Post ReplyReply bullet Posted: 24 Feb 2023 at 9:57am
fwfdfireman View Drop Down
  Quote fwfdfireman Quote  Post ReplyReply bullet Posted: 24 Feb 2023 at 3:54pm
JayzTwoCents mentioned that the drive that seems to be affected the most is the Samsung 980 Pro 2TB, I stress the 2TB. I have not been able to find anything that states all the 980 Pro NVMEs are affected.
Edited by fwfdfireman - 24 Feb 2023 at 4:05pm
Old Gamers Never Die!
  Quote hoserator Quote  Post ReplyReply bullet Posted: 24 Feb 2023 at 11:43pm
If you are running the 980 Pro 2TB, check its firmware and make sure it is NOT 3B2QGXA7. (In W7; Control Panel>Device Manager>open drives and right click on the 980>Properties>Details>Device Description>Hardware ids on drop down menu.)
If you have 4B2QGXA7 or 5B2QGXA7 (latest) it should be ok.
  Quote JamesAstro Quote  Post ReplyReply bullet Posted: 25 Feb 2023 at 2:30pm
I decided to upgrade my firmware to the latest even though my SSD didn't have the bug. The upgrade was easy and painless.
This page was generated in 2.050781E-02 seconds.
