Samsung P2370 Monitor Questions
Post Date: 2009-11-04
B5GkarNarn View Drop Down
  Quote B5GkarNarn Quote  Post ReplyReply bullet Topic: Samsung P2370 Monitor Questions
    Posted: 04 Nov 2009 at 8:47pm
I went to a local Best Buy & saw the Samsung P2370 Widescreen LCD monitor on display.  It was running some sort of video & the picture quality was very good.
DST4ME has mentioned that it is a good idea to look for a monitor that has the same viewing angle for both horizontal & vertical and they should be above 170 degrees.  Unfortunately, the Samsung P2370's viewing angles for horizontal and vertical are off by 10 degrees:  170 degrees for horizontal & 160 degrees for vertical.  Should I look for a different monitor?  What are your thoughts?
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 04 Nov 2009 at 9:34pm
if you want to make sure you don't get a tn panel then the viewing angles have to match and be higher then 170, otherwise the quality of the picture is not gonna be that great.
Edited by DST4ME - 04 Nov 2009 at 9:34pm
  Quote B5GkarNarn Quote  Post ReplyReply bullet Posted: 05 Nov 2009 at 9:47pm
Unfortunately, my budget does not allow me to spend more than $300 for a monitor and according to the following article on the AnandTech website, it's highly unlikely that I'll be able to purchase a non-TN panel within my price range:
Are you able to recommend a non-TN monitor that does not cost more than $300?
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 05 Nov 2009 at 9:58pm
look at this list
Edited by DST4ME - 05 Nov 2009 at 10:07pm
  Quote B5GkarNarn Quote  Post ReplyReply bullet Posted: 06 Nov 2009 at 1:24pm
look at this list
Unfortunately, the only monitor in that list that had a screen size of 23"- 24" and a response time that was 5 ms or less was the NEC ASLCD24WMCX - but it costs $150 more than my budget will allow.  Many of the other monitors in that list had a response time of 8 ms and I feel that number is way too high for gaming purposes.
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 06 Nov 2009 at 2:15pm
response time is bs, there is no real way of measuring it, companies use grey to grey or black to black because it produces a smaller number, don't let the response time fool you.
also tn panels have a supposed faster response time but lack quality, non tn panels have better quality but a little slower response time.
  Quote B5GkarNarn Quote  Post ReplyReply bullet Posted: 13 Nov 2009 at 6:46pm
I'm going with Samsung P2370 because I had the chance to see it running at a 2nd store and it looks fabulous.  My wife was with me and she agreed with me.  I'll have to live with the fact that it is a TN panel and that the height is not adjustable.  Things could be worse.
titusmckieus View Drop Down
  Quote titusmckieus Quote  Post ReplyReply bullet Posted: 21 Nov 2009 at 12:29am
I just purchased two asus monitors . One for my computer, and one to set up my PlayStation out in the living room. I never played it when it was hooked up to  the bedroom TV.
http://www.newegg.com/Product/Product.aspx?Item=N82E16824236047
for being a  panel with a  viewing angle of 170°(H) / 160°(V)  these monitors are nice.
I also have the Samsung T240
 http://www.newegg.com/Product/Product.aspx?Item=N82E16824001275
I like the Asus 25.5 better then the samsung . Once you find the right angle to set the monitor at it's not that bad.  for the price.
my samsung is a different story . if i moved around to much in the chair while playing a game I lose that "sweet spot" and next thing you know i cant even see the screen.
Edited by titusmckieus - 21 Nov 2009 at 12:32am
