SB xf-i titanium fatality pro help
Post Date: 2008-10-17
Daygn View Drop Down
  Quote Daygn Quote  Post ReplyReply bullet Topic: SB xf-i titanium fatality pro help
    Posted: 17 Oct 2008 at 3:50am
I did not like the choices DS offered so I bought a xf-i titanium pcie x1 to install when I get my pc and just found out that vista does not support directsound3d. I use digital 5.1headphones that use a fiberoptic cable and am wondering if I am going to get 5.1 and eax5.0? Three people at DS told me to bring it when I pick up my pc and they would install and configure it, but one perison I talked to said they do not do that anymore and was harsh about the wholething. If I do install it myself is there any info someone (DST4ME) can give me to help me out?
BB
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 17 Oct 2008 at 3:59am
I thought the creative supported eax5.0, its the razer that does not support it.
OK now you need to get that person's name that was harsh to you and give his name to Alex, Alex doesn't tolerate anybody being harsh with the customer.
second to change a sound card is as easy 1, 2 and 3, I would be more then happy to walk you thru it, but first lets make sure you need to change the sound card to begin with.
now is yours the Fatal1ty Pro version or the regular?
  Quote Daygn Quote  Post ReplyReply bullet Posted: 17 Oct 2008 at 5:11am
It is the pro verison. I know how to install a new soundcard. I have done it afew times before. What I was asking is if the issue with vista and games that use directsound3d has been fixed? I learned about this issue on the soundblaster.com when checking if the fatality pro used 64-bit drivers. It was creativelabs who said eax5.0 and 5.1 surround do not work with games that support directsound when using vista. Their is some program that corrects this prob. until creative makes new hardware that uses a different API. OpenAL I think.
BB
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 17 Oct 2008 at 5:24am
aha, I see, well I'm not that great in this area, but you got the latest drivers for the card? cause the only way to fix that issue in that card would be with drivers, if its possible to begin with.
I read asus's card works in those conditions
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 17 Oct 2008 at 5:29am
have you seen this?
Edited by DST4ME - 17 Oct 2008 at 5:30am
  Quote Daygn Quote  Post ReplyReply bullet Posted: 17 Oct 2008 at 6:08am
That is the program I was talking about. Do you know anything about it, does it work or still have issues? I don't get the pc untill hopefully next week so no drivers to update or install yet. I would reply faster but im at work and you can only type so fast on a LG Dare.
BB
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 17 Oct 2008 at 6:09am
apparently that is your work around, I don't have it but this is what you need to get it to work with games that support DS3D in vista
  Quote Daygn Quote  Post ReplyReply bullet Posted: 17 Oct 2008 at 6:54am
Hey thanks for all of your help over the past few days. This is the first fourm I have been a member of and you have helped me out alot when you could. Im sure I will need more help with my new rigg and somehow found a good place to find it. Thanks again.
BB
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 17 Oct 2008 at 6:56am
don't mention it, its my pleasure
  Quote Daygn Quote  Post ReplyReply bullet Posted: 17 Oct 2008 at 6:57am
Any other fourms you could reccomend me?
BB
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 17 Oct 2008 at 7:08am
depends on the subject.
  Quote Daygn Quote  Post ReplyReply bullet Posted: 17 Oct 2008 at 7:58am
Pc hardware/vista64/utilites/software/overclocking just a good pc related one.
BB
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 17 Oct 2008 at 8:23am
vista 64bit go here
for software, click my sig, left side is the site, right side of the sig is the forum
overclocking there is bunch, why don't you start with extremeoverclocking, overclock.net, and xbitlabs should be a good place to start
Mezzeron View Drop Down
  Quote Mezzeron Quote  Post ReplyReply bullet Posted: 17 Oct 2008 at 11:56pm
Is that an issue with just 64 bit systems or vista as a whole
  Quote Daygn Quote  Post ReplyReply bullet Posted: 17 Oct 2008 at 11:59pm
With vista but creative has a program to fix it
BB
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 18 Oct 2008 at 1:12am
its whole vista cause it does not support DS3D, but Alchemy will take care of it apparently
