Seeking Help with a Gaming Computer Design
Post Date: 2011-10-11
Edaar09 View Drop Down
  Quote Edaar09 Quote  Post ReplyReply bullet Topic: Seeking Help with a Gaming Computer Design
    Posted: 11 Oct 2011 at 10:47am
Hi! I am trying to design a new computer and upgrade from a GTX 9800, Q6600 quad corp processor, 3 gigs of ram gaming rig. It is about 4.5 years old and I am trying to determine the best choice for a new system. After looking here and on newegg and some other sites I thought this set up would work best. I had a couple questions though:
1) To SLI or Not to SLI. From what I have read SLI doesn't grant all that great of an increase in gpu power, approximately 20-30%? If that is the case would it make more sense to spend the money on a single graphic cards that is more powerful?
2) I chose the Noctua NH-D14 over the water coolers, is this a good option with a more powerful gpu?
3) I was wondering if I could get green led in the case rather than red or blue?
I would appreciate any guidance here in helping me create this gaming rig. I want to get this right and have something that will last the way my former rig has, which has been capable of playing most games up until the last few months. Thanks!
Budget: $2,500.00-$3,000.00
Expectations: A primarily gaming computer with capability of running Skyrim, Star Wars the Old Republic, BF3, while not breaking the bank account that will last, with minimal upgrades, for up to 4-5 years (minimal upgrades including potential video card upgrade or implementing SLI)
Usage:75% gaming, 10% video/picture/amv creation, 15% general use/microsoft office
All Green Led lighting
LCD fan control and monitor
Hard Drive Set 2: Multimedia\Data: 1x Western Digital VelociRaptor WD6000BLHX 600GB 10000 RPM 32 MB Cashe 2.5’ SATA 6.0G/s Internal Enterprise Hard Drive OR 1x (1TB Western Digital Caviar (7200 RPM) (64MB Cache) (Model: Black Edition)
Optical Drive 1: SAMSUNG Black 12X BD-ROM 16X DVD-/+R 48X CD-ROM SATA Internal Blu-ray Combo Model SH-B123L/RSBP Lightscribe Support
Video Card(s): Either 1x EVGA 03G-P3-1584-AR GeForce GTX 580 (Fermi) 3072MB 384-bit GDDR5 PCI Express 2.0 x 16 HDCP Ready SLI Support Video Card OR 2x SLI Dual (NVIDIA GeForce GTX 570 1.2GB (Includes PhysX Tech) (EVGA Edition)
Sound Card: Creative Sound Blaster X-Fi Titanium Fatal1ty Professional 70SB088600002 7.1 Channels 24-bit 96KHz PCI Express x1 Interface Sound Card
Extreme Cooling: AIR: Noctua NH-D14
Internal Lighting: - Green led
Chassis Mods: - Scythe Kaze Master Temperature Display & Fan Controller (Requires Chassis Airflow Upgrade) (KM01-BK)
CPU Boost: Stage 2: Overclock CPU 4.5GHz to 4.8GHz (Requires Pro or Deluxe Series Motherboard)
Office: - Officer 2010 Home and Student
Pre-Install Game: FREE: Batman: Arkham City (Available only with NVIDIA GeForce GTX graphic cards)
Exclusive T-Shirt: FREE: Digital Storm T-Shirt - Black (Extra Large)
Thank you again!
-Edaar
Unlicensedhitman View Drop Down
  Quote Unlicensedhitman Quote  Post ReplyReply bullet Posted: 11 Oct 2011 at 1:48pm
You should go with the 2x GTX 570's.
Digital Storm xm15 laptop
-15.6" (1366x768)
-Windows 7 HP 64-bit
-Intel Core i5 2.4 Ghz
-Nvidia GeForce 330GT 1GB + Intel HD w/ Nividia Optimus
-6GB DDR3 ram
-Intel 80GB SSD
-Intel Wireless N 6300
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 11 Oct 2011 at 4:03pm
1. there is no single card that is more powerful, if you pic your sli correctly.
in some games sli will have no effect, in some games it will double your performance.
2. cpu cooler has nothing to do with gpu cooling/choice. both a70 and noctua are king till you get to stage 4.
fans don't come in green the haf x has a 230mm red led fan upfront which will not get changed, and if you do change it, they will change it with a smaller louder fan.
fan controller will not control any fans and its temps are not accurate.
sli 570 will eat a single 580 for snack in games like bf3.
your build looks good, hdd2 should be 1TB black caviar, the gpus should be sli 570, but to be sure I need to know your res. drop the fan controller.
What is the native resolution of the monitor you gonna be gaming at?
  Quote Edaar09 Quote  Post ReplyReply bullet Posted: 11 Oct 2011 at 4:10pm
The resolution for the monitor is 1920 x 1080. It is a ASUS VW246H Glossy Black 24" 2ms(GTG) HDMI Widescreen LCD Monitor 300 cd/m2 ASCR 20000:1 (1000:1)
-Edaar
Edited by Edaar09 - 11 Oct 2011 at 4:12pm
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 11 Oct 2011 at 4:19pm
fyi:
1. response time is a bs number, its there to fool you and does not represent the true response time of the monitor, there is no real way of truly finding what response time is, the closest to it is white to white but you don't see that, you see grey to grey or black to black cause they give small numbers to fool users but they don't mean anything, there are different methods to get these numbers also, and each will give a different number as results, therefore you can even compare one to the other, cause we don't know what method was used for which, and even if we did, still GTG or BTB don't mean anything.
2. contrast ratio is also bs number.
do you already have that monitor? if yes then you gonna want sli 570 for it.
  Quote Edaar09 Quote  Post ReplyReply bullet Posted: 11 Oct 2011 at 4:23pm
Not yet, I was waiting to purchase the the desktop rig before I decided on the monitor. Would you recommend something different?
-Edaar
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 11 Oct 2011 at 4:39pm
Ya an IPS panel and I have and lot of people here have and love:
Dell UltraSharp u2312
Dell UltraSharp U2410M
they are pretty much the same you can get the 23" for $260 on sale or with a coupon.
go here and see if this coupon still works
Edited by DST4ME - 11 Oct 2011 at 4:40pm
  Quote Edaar09 Quote  Post ReplyReply bullet Posted: 11 Oct 2011 at 4:49pm
Thank you very much, I will definitely get pick up the Dell UltraSharpu2312.
So the end result for my pc should be
Video Card: 2x SLI Dual (NVIDIA GeForce GTX 570 1.2GB (Includes PhysX Tech) (EVGA Edition) <b></b>
Sound Card: Creative Labs X-Fi Titanium Fatal1ty Professional
Chassis Airflow: Upgrade Chassis With LED Performance Fans (Green) (Up to 6 Fans)
Enhancements: - No Thanks <b></b>
Office: Microsoft Office 2010 Home and Student (Full Retail Box Packaging)
Install/Test Game: FREE: Batman: Arkham City (Available only with NVIDIA GeForce GTX graphic cards)
Does that look good?
-Edaar
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 11 Oct 2011 at 5:27pm
LOL you fix one thing but them messup the other one
but seriously, the upgraded fans are smaller and louder, the hailstrom is not a case you want for air cooled system, we recommend that case for systems with lc on cpu/gpu, so change that back to hafx, it has great airflow and we highly recommend it for air cooled system.
so go back to haf x and drop fan upgrade. there is no way to make haf green without losing airflow and keeping the same noise level.
if you want red or blue then I can show you the 200mm fans in those colors.
one more option is to get teh haf x nvidia edition, which comes with front 230mm led fan as green, but cm does not offer the 200mm fans in green. so the three 200mm fan spots can't have 200mm green fans in them.
Edited by DST4ME - 11 Oct 2011 at 5:28pm
  Quote Edaar09 Quote  Post ReplyReply bullet Posted: 11 Oct 2011 at 5:46pm
I didn't see the Hafx as an option for the black op's machines where I had all of other customization options, it was only available in the special op's machines. Can I get DS to use the Nvidia Hafx with these specs?
-Edaar
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 11 Oct 2011 at 6:08pm
No the only difference between blackops and special ops is price, just go to the other side and pick the same components and the haf x case.
here:
Ticket Number: 604732
pic green lighting.
Edited by DST4ME - 11 Oct 2011 at 6:10pm
  Quote Edaar09 Quote  Post ReplyReply bullet Posted: 11 Oct 2011 at 9:32pm
Thank you very much!!  I'll be ordering it in the next few days :D
-Edaar
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 11 Oct 2011 at 11:59pm
My pleasure and good luck Don't forget to post review and pics of it when you get it
