Serious buyer looking for help
Post Date: 2011-05-23
Anaahat View Drop Down
  Quote Anaahat Quote  Post ReplyReply bullet Topic: Serious buyer looking for help
    Posted: 23 May 2011 at 3:54am
Hi everyone, I have been looking for a VERY high end gaming computer, and I have looked along many sites and many configurations, but I believe that I will eventually end up with a Digital Storm Computer.
So I just need some help with my configurations, and if someone could help me, I would greatly appreciate that
My Budget: Around 6000 for the actual computer, I can handle shipping costs on the side
Expectations: I am looking for an dual SLI setup of either nVidia gtx 580's or 590's. I want this computer to excel at multi-tasking (EG, running youtube videos while gaming and downloads running in the background) and just destroy any game that can be thrown at it.
Usage: basically gaming and general websurfing
Special Needs: I just want the highest overclocks, with some of the BEST liquid cooling to keep it stable, an intel core 990x processor is a MUST and enough  SSD memory for my processing system, my web browser and a couple of games (just around 120gb) then about 1-2 TB of hard drive space. I would also like around 12 GB of Ram
here is one of the comp configurations i had, and it is just a little too expensive.
http://www.digitalstormonline.com/comploadsaved.asp?id=539352
thanks everyone !
zangetsu View Drop Down
  Quote zangetsu Quote  Post ReplyReply bullet Posted: 23 May 2011 at 4:10am
2600k beats the 990x in gaming. 990x beats the 2600k in heavy-threaded applications.. so if you want to go with the 990x just for gaming you'd be wasting alot of money.  There are numerous benchmarks to prove the 2600k beats the 990x in gaming, and it barely falls behind encoding etc.
The case you chose is horrible for liquid cooling. It's way too small, if you're wanting a Liquid cooling build, hailstorm is the better choice.
The 590 card is a dual GPU card, that creates alot of heat. The new drivers may have fixed the OC ability on them, but they still run hot. Your better choice is to run with two 580's or two 6970's depending on your monitors native resolution.
If you're only going to be gaming/websurfing, there is no reason to get 12gb of memory, having 6-8 is pretty much perfect for gaming and multitasking. Now if you want 12 gb then shoot for it, but getting more RAM than you need can slow down the computer as well..
Here is a suggested build... you can tweak it. With the p67/2600k build you can go Tri SLI, but itll actually be slower because the PCI lane is 8x/8x/4x.. now if you want Tri SLI, you can choose to go with the old x58 build, because those mobos are 16x16x8x. Or do as alot of people are doing and wait till the new Sandy Bridge Chips come out that will be 6cores and 8 cores, and they will destroy everything on the highend.
Saved Ticket Number: 547437
Hard Drive Set 1: Operating System: 1x (160GB Solid State (By: Intel) (Model: 320 Series SSDSA2CW160G3K5)
Video Card: 2x SLI Dual (NVIDIA GeForce GTX 580 1.5GB (Includes PhysX Technology)
Extreme Cooling: H20: Stage 6: Sub-Zero LCS Dual Loop: CPU & Dual SLI/CrossFire Video Cards
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 23 May 2011 at 4:15pm
@Anaahat, what res you plan on gaming on?
