shoping for a mobo...(help)
Post Date: 2009-09-08
kainhall View Drop Down
  Quote kainhall Quote  Post ReplyReply bullet Topic: shoping for a mobo...(help)
    Posted: 08 Sep 2009 at 9:31pm
shoping for a mobo makes me want to bunch babies.
i find one with all the right crap and its the type that melts down or is dead on arival every time (asus???)
hear are the requirments for my moms computer
scocket: lga 775
pcie 2.0: atleast 2 in 16x each
form factor- anything
relibalty- great i dont want to travel to MN to fix her mobo
3/4pin fans- as many as posible (must be able to power the cooler master HAF case)
i have looked at new egg and like i said i want to punsh babies. or at least kick the wall.
if you find a good one plesae send me a link on newegg or any other site.
thank you so much! now i can dump my frustration on some one else YAAA
again thanks and....happy hunting??Ouch
steam friends is kainhall
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 09 Sep 2009 at 7:49am
try the evga 790i
  Quote kainhall Quote  Post ReplyReply bullet Posted: 09 Sep 2009 at 11:48pm
lol newegg does not carry that anymore
XFX MBN790IUL9 LGA 775 NVIDIA nForce 790i Ultra SLI ATX Intel Motherboard
but it does carry that
my main worrie is that the pcie both run in 16x even with all the slots filled and that if i put like mushkin 2000mh memory in it will it work
and YOU tell me if there are any other probelems with this board
is it a good mobo or a crapy one that will fail like mac/apple....... thats right i said it!!
thanks
  Quote kainhall Quote  Post ReplyReply bullet Posted: 09 Sep 2009 at 11:49pm
by the way here is the newegg link!!
venom View Drop Down
  Quote venom Quote  Post ReplyReply bullet Posted: 09 Sep 2009 at 11:55pm
Wow great price on that 790i, I remember when they retailed for $300-400.  The 790i will be able to handle everything that you are asking for (3 16x slots, 2000MHz RAM).  Though about the RAM, make sure you install it in the black slots, and only use 2 sticks, 4 will not work at all.
  Quote kainhall Quote  Post ReplyReply bullet Posted: 11 Sep 2009 at 12:05am
o noes ONLY 2 STICKS OF RAM
bios update or if i use slower ram. im trying to get 6 gigs it this beast
do they make 3gig ram sticks???
and by the way THANK YOU
  Quote venom Quote  Post ReplyReply bullet Posted: 11 Sep 2009 at 12:07am
You could have 8GB (4x2GB) of 1600 or 1333 ram, but anything higher and you will have to only use 2.
  Quote kainhall Quote  Post ReplyReply bullet Posted: 11 Sep 2009 at 12:38am
so would 3 2 gig sticks of 1600 work??? or would i have to go with just 4
  Quote venom Quote  Post ReplyReply bullet Posted: 11 Sep 2009 at 12:40am
You can do 3, though I don't think it will be running in Dual Channel mode if you do.
  Quote kainhall Quote  Post ReplyReply bullet Posted: 11 Sep 2009 at 12:43am
what?? its tri channel ddr3 memory
so 4 will run at full speed no probelms but 3 sticks might run at 2 channels and might only reconzise 2 sticks
i dont know but sorry to bug im almost a noob at memory
  Quote venom Quote  Post ReplyReply bullet Posted: 11 Sep 2009 at 12:46am
The 790i does not support triple channel, only dual, though you can buy a triple channel kit and use it, but like I said it will run single channel on all 3.
4 sticks will run in dual channel mode, 2 will also run in dual channel mode.
  Quote kainhall Quote  Post ReplyReply bullet Posted: 12 Sep 2009 at 6:43pm
hummm so that makes ddr3 useless
well i dont know the ram for windows 7 but,
well this mobo make the ddr3 as slow as ddr2
i know ddr3 has MUCH higher clocks but if the clocks were the same tri-channel ddr3 woukld be faster then 2 channel ddr3/ddr2???
