Side Case Issue
Post Date: 2016-08-02
Rigz21 View Drop Down
  Quote Rigz21 Quote  Post ReplyReply bullet Topic: Side Case Issue
    Posted: 02 Aug 2016 at 7:16pm
Hi, hopefully this is the right section if not,I can repost in the correct area. I have the Velox 3 system with a side panel that has a gpu fan; however, when I was cleaning out my pc I accidently pulled the case a little too hard and pulled the plug on where the fan originally went, and have no idea where it goes. Any help would greatly be appreciated!
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 02 Aug 2016 at 7:49pm
I don't have much experience with that case but
It either goes on the mobo or to a psu connection like a 4 pin or a 3 pin, look for a loose connection right around the window, you should see it, otherwise it was connected to the mobo.
have you taken it out before? do you remember how it was or is this the first time?
Edited by DST4ME - 02 Aug 2016 at 7:49pm
  Quote Rigz21 Quote  Post ReplyReply bullet Posted: 02 Aug 2016 at 7:52pm
I've never noticed it before; however, I pretty sure it goes on the mobo, just don't know where
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 02 Aug 2016 at 7:53pm
Your mobo?
  Quote Rigz21 Quote  Post ReplyReply bullet Posted: 02 Aug 2016 at 7:57pm
Its a 3 pin and I'm pretty sure I noticed the cable running above my gpu, which would lead me to it being on the mobo as I've ran through my computer looking at the wires
  Quote Rigz21 Quote  Post ReplyReply bullet Posted: 02 Aug 2016 at 8:41pm
Nvm found it. Thank you guys so much for the help!
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 02 Aug 2016 at 10:29pm
No problem sorry I couldn't point it out to you without knowing make/model of the mobo
