Side Panel Fan Connector
Post Date: 2010-08-30
Popi View Drop Down
  Quote Popi Quote  Post ReplyReply bullet Topic: Side Panel Fan Connector
    Posted: 30 Aug 2010 at 10:08am
My new computer was delivered on Friday at 5PM, by FEDEX.
Order Number 13077.    942 HAF X.
The side panel fan 3 pin female standard power connection has a extention power connector.  This extention has both female and male 4 pin power connectors which
appears to be used, to bypass the 3 pin connector.  If that 4 pin 12v is supposed to be connected to the power supply (750W), I did not find the power connect location.
Anyone... Where does the 4 pin get connected?
  Quote !ender_ Quote  Post ReplyReply bullet Posted: 30 Aug 2010 at 10:37am
should be bottom right if you are facing in the open window, or it may reach the mother board
Popi View Drop Down
  Quote Popi Quote  Post ReplyReply bullet Posted: 30 Aug 2010 at 11:06am
lender
I took off the 4 pin extension and used the 3 pin on the mobo. Works OK.
I should have stated that the mobo is a EVGA X58 LE.
Sorry. Once again about the 4 Pin.  Where can it be connected, mobo or power supply?
  Quote !ender_ Quote  Post ReplyReply bullet Posted: 30 Aug 2010 at 11:18am
both are fine, if its 4 it will likely still fit on a motherboard 3pin or a power supply 3 pin
Popi View Drop Down
  Quote Popi Quote  Post ReplyReply bullet Posted: 30 Aug 2010 at 11:48am
OK   DSO should add a sticker on the 4 pin if they want us to use the extension.
Thanks lender.  This unit is for my daughter.  Later, another unit will be ordered
in October.
Warpig View Drop Down
  Quote Warpig Quote  Post ReplyReply bullet Posted: 30 Aug 2010 at 1:13pm
in October.
Please let us know how the unit is and put up some pictures if possible.
