Side window fan for the 950si case?
Post Date: 2008-11-29
JamesAstro View Drop Down
  Quote JamesAstro Quote  Post ReplyReply bullet Topic: Side window fan for the 950si case?
    Posted: 29 Nov 2008 at 5:45pm
Hey, what do you guys think about getting the side window fan for the 950si case? Personally I think it will take away from the appearance, and might make opening the case more difficult. Plus it will add some extra noise, and I'm not sure if my video cards need the extra air anyway. (I'm not overclocking the video.)
What do you think?
James
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 29 Nov 2008 at 6:00pm
I say depends on your system, you are getting triple sli right? if yes with LC or no?
  Quote JamesAstro Quote  Post ReplyReply bullet Posted: 29 Nov 2008 at 7:18pm
I think I'm going with triple sli and air cooling without video overclocking.
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 29 Nov 2008 at 7:22pm
then the HAF is better for you, the 950si does not have the airflow that HAF has, the 950si is a great case if you got everything liquid cooled
Rad!caL View Drop Down
  Quote Rad!caL Quote  Post ReplyReply bullet Posted: 29 Nov 2008 at 8:30pm
QFT
Although the HAF is the best case for liquid cooling as well as air cooling.
