Silence x Power
Post Date: 2011-01-14
usuario View Drop Down
  Quote usuario Quote  Post ReplyReply bullet Topic: Silence x Power
    Posted: 14 Jan 2011 at 11:43am
[$ 5.000]
[Play the more demanding games at high resolution ( 2560 x 1440 Dell U2711 Monitor )
[Gaming]
Although I know a power system can not be that silent I would like to have a system as silent as it can be. Any sugestion would be highly appeciated.
Thanks for the advice guys
Edited by usuario - 14 Jan 2011 at 12:32pm
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 14 Jan 2011 at 3:20pm
Ticket Number: 478316
that will let you play practically all games at highest settings with all bells and whistles.
if you don't need all that drop to dual sli.
to make it really quiet you need to request the rads used to be feser or xspc rads, and Scythe
"GentleTyphoon" fans, this will cost extra.
also if you want good temps go with at least a dual rad for cpu and triple rad for gpus.
  Quote usuario Quote  Post ReplyReply bullet Posted: 14 Jan 2011 at 5:46pm
UAU!!!!
Thanks a lot!!
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 14 Jan 2011 at 5:51pm
My pleasure and good luck
btw go with 8GB of ram, I forgot to change that, 64bit needs 2GB of ram to itself so you gonna want more then 2GB of ram for the rest of the apps.
Edited by DST4ME - 14 Jan 2011 at 5:51pm
  Quote usuario Quote  Post ReplyReply bullet Posted: 15 Jan 2011 at 11:17am
OK
