Silverstones Second Raven Case Review
Post Date: 2009-09-26
  Quote <8) slunK parade Quote  Post ReplyReply bullet Topic: Silverstones Second Raven Case Review
    Posted: 26 Sep 2009 at 7:18pm
Techkai View Drop Down
  Quote Techkai Quote  Post ReplyReply bullet Posted: 26 Sep 2009 at 8:53pm
they should have used the fans and size of the rv02 with the style and design of the rv01 to make the ultimate case Unhappy
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 26 Sep 2009 at 11:03pm
the first one sucked bad, this one isn't far from.
  Quote Alex Quote  Post ReplyReply bullet Posted: 26 Sep 2009 at 11:21pm
We are actually thinking of offering it. It has good airflow, and design IMO?
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 26 Sep 2009 at 11:57pm
I don't see it, all its got is 4 x 120mm fans, connections are on top, you get only 7 drive slots, 4 media and 3 HDDs, even the review says working on it is not as easy as other cases, for LC it has basically no room, sides have the psu and HDDS, top has the extension packs, and bottom is your air flow, so room for rad is basically non existent.
you will also have room trouble with media drives and gpus as the media drives stick out where the gpus go, even the review says that they could not have gpu and dvd drives.
at its price range, the haf and 950 is better, and hailstorm is a much better/roomier case for LC enthusiast.
