simple advice
Post Date: 2008-04-18
jyduchene View Drop Down
  Quote jyduchene Quote  Post ReplyReply bullet Topic: simple advice
    Posted: 18 Apr 2008 at 8:13pm
I have a DS on the way. I have a Dell 2408 and ovewhelmed with connection lingo if not choices
here is the Dell spec. for connections
VGA (Analog), DVI-D (Digital) with HDCP, S-Video, Composite, Component, HDMI, DisplayPort
My computer will be SLI with two 8800 GT's so which connection do I use and which card. I assume two cards stick out the back, do I use the upper or lower card?
Thanks for the info. I relearn computer specs every ten years!
John
skyR View Drop Down
Digital Storm Apprentice
  Quote skyR Quote  Post ReplyReply bullet Posted: 18 Apr 2008 at 8:44pm
You plug it into the top card.
  Quote jyduchene Quote  Post ReplyReply bullet Posted: 18 Apr 2008 at 9:59pm
Thanks, Now which ?
John
skyR View Drop Down
  Quote skyR Quote  Post ReplyReply bullet Posted: 18 Apr 2008 at 10:10pm
It's recommended to use DVI.
This page was generated in 5.712891E-02 seconds.
