Single Video Card, two monitor advice
Post Date: 2012-01-13
queloque View Drop Down
  Quote queloque Quote  Post ReplyReply bullet Topic: Single Video Card, two monitor advice
    Posted: 13 Jan 2012 at 2:44pm
With my single 570, I can game on one screen full settings and desktop on the other screen, am I correct?
I have two 24 inch monitors.
This is all done with windows settings adjustment, am I correct?
I believe this was discussed but with two cards.  I only have one.
Thanks
mordrick78 View Drop Down
  Quote mordrick78 Quote  Post ReplyReply bullet Posted: 13 Jan 2012 at 6:14pm
You are correct that you can run 2 monitors off of 1 card. I do it on both my and my wife PC.
To set it up once you connect the 2nd monitor you just right click on your main monitor's screen and go to screen resolution.
Under orientation is where you choose to extend your desktop to the 2nd monitor.
