Slade Cooling
Post Date: 2014-04-17
gary2232 View Drop Down
  Quote gary2232 Quote  Post ReplyReply bullet Topic: Slade Cooling
    Posted: 17 Apr 2014 at 8:17pm
Got my new Slade up and running. And it is great. But I noticed the fan pushing some pretty warm air? Is there a temperature monitor I should be checking? Do not want to over heat. By the way this thing is so quiet you can not tell it's running.
  Quote ArkansasWoman777 Quote  Post ReplyReply bullet Posted: 17 Apr 2014 at 9:06pm
http://www.cpuid.com/softwares/hwmonitor.html, http://www.techpowerup.com/realtemp/
  Quote Snaike Quote  Post ReplyReply bullet Posted: 17 Apr 2014 at 11:30pm
HWMonitor and Speccy are great programs for monitoring temps.  HWMonitor has a min / max view so  you can zero them out, game on and then check for peaks when you're done.
Edited by Snaike - 17 Apr 2014 at 11:31pm
