SLI and power supplies
Post Date: 2010-10-26
police215 View Drop Down
  Quote police215 Quote  Post ReplyReply bullet Topic: SLI and power supplies
    Posted: 26 Oct 2010 at 6:53am
Looking to add another GTX470 card running SLI. I have a 750 watt power supply and just want to know if that's going to be enough.
  Quote justin.kerr Quote  Post ReplyReply bullet Posted: 26 Oct 2010 at 8:36am
Yes it will run it. you will be running it hard, but it will run it. Should be pulling 680-730 watts out of the power supplly under max load with everything overclocked.  If you have BFBC2 play for several hours, that will test the 2 GPU's and use 6 threads on the CPU. Big%20Smile
  Quote police215 Quote  Post ReplyReply bullet Posted: 26 Oct 2010 at 8:40am
thanks Guys!!! I'm ordering it now!!
Edited by police215 - 26 Oct 2010 at 8:46am
  Quote !ender_ Quote  Post ReplyReply bullet Posted: 26 Oct 2010 at 8:42am
yes, technically, though i wouldnt look forward to any big overclocks
if that doesnt bother you, go for it
  Quote police215 Quote  Post ReplyReply bullet Posted: 26 Oct 2010 at 8:58am
the price really went down $259.00 free shipping
  Quote justin.kerr Quote  Post ReplyReply bullet Posted: 26 Oct 2010 at 9:19am
You can go big for air overclocks, you are just pushing the power supply, no harm, biggest con would be the fact it will be out of peak efficiency. While gaming, I doubt you will be pulling more than 700 watts from the power supply, so around 800-870 at the wall.
My wife ran a Corsair 750 watt PS for many years on a system with about the same power requirements, and now that power supply is now in a HTPC 24/7 use, and has been for years.
Ideally you would want a Corsair HX 850, that way, under max draw, you would be running in the "sweet spot" for efficiency, but lol you will be fine.
  Quote police215 Quote  Post ReplyReply bullet Posted: 27 Oct 2010 at 10:35pm
The power supply that came with the computer doesn't have all the power connections to run 2 470's
I have one set of 8 pin and next to that I have one set of 6 pin connectors. So I need one 8 pin to 6 pin to run both cards
