SLI tips, info and help
Post Date: 2008-11-03
Daygn View Drop Down
  Quote Daygn Quote  Post ReplyReply bullet Topic: SLI tips, info and help
    Posted: 03 Nov 2008 at 2:46am
What are some common issues people might have when using two way SLI? When playing warhead I see a ghost image. It is kind of like two images on top of eachother. Also when Iook at the gpu clock speeds they are at 301??
BB
jtspectra2 View Drop Down
  Quote jtspectra2 Quote  Post ReplyReply bullet Posted: 03 Nov 2008 at 2:23pm
YA im kinda interested in some common issues as well being that my new DS system is the first system i have owned with SLI.
im a complete newb when it comes to having more then one GPU . im still stuck in the AGP era Big%20smile
Edited by jtspectra2 - 03 Nov 2008 at 6:09pm
TomD View Drop Down
  Quote TomD Quote  Post ReplyReply bullet Posted: 03 Nov 2008 at 9:58pm
I have never seen ghosting with SLI or seen complaints that it is a common problem. I would try disabling SLI to see if it goes away - my guess is that it won't, but I have been wrong before. (You can disable it in the NVidia Control Panel).
As for the gpu clock speed at 301, NVidia cards downclock when not under load to save energy and reduce temperature. It will spike back up as soon as you start doing anything. It does this whether you have SLI or not and is normal. Similar to Intel speedstep on the CPU.
  Quote Daygn Quote  Post ReplyReply bullet Posted: 03 Nov 2008 at 10:01pm
Thanks for the info.
BB
