Slow ripping speed -- any help for it?Post Date: 2014-05-31 |
Socks223
Newbie Joined: 11 Mar 2014 Online Status: Offline Posts: 38 |
Topic: Slow ripping speed -- any help for it? Posted: 31 May 2014 at 10:51pm |
My DS slade (delivered 4/14) w/ASUS DRW24-F1ST optical drive. When burning CDs via Itunes, it won't go above 3.4x speed, and sometimes takes 3-5 minutes to burn a 1 minute track. Does anyone know what's causing this? And how to fix it? Tried google and forum search but didn't find anything.
Theokritos
Senior Member Joined: 28 Feb 2014 Online Status: Offline Posts: 688 |
Quote Reply Posted: 31 May 2014 at 11:32pm |
Speed can be limited by the DVD/CD media that you are using. I too have a new Slade and I have been burning a number of Linux Distribution .iso files to DVD. My first few were rather slow as you described. I finally compared the speed range between two sets of blank DVDs and found that the ones that I first used ranged from 1x - 4x while the second set ranged from 1x - 16x. Naturally I switched media and my recording session sped up as well.
Velox
Cool and Quiet AMD Ryzen 9 7900X 32GB DDR5 5200MHz Radeon RX 7900 XTX |
Socks223
Quote Reply Posted: 01 Jun 2014 at 9:57am |
Hmm. . . that's interesting. Hadn't considered that the disc itself might restrict rip/burn times. Makes sense, though. But I'm ripping CDs from several different sources and it's the same problem. Not worth a tirade, of course -- it's just irritating and I'd prefer not to deal with it. Thanks for the tip though.
