Small tips about build
Post Date: 2013-12-26
godfather2009 View Drop Down
  Quote godfather2009 Quote  Post ReplyReply bullet Topic: Small tips about build
    Posted: 26 Dec 2013 at 4:44am
Hi guys
i just need small question about my new build
First power supply
Do i use the 1500 EVGA super nova classified or the 1500 Silverstone
which one is the best and deliver the best performance on ultimate gaming performance
Second the monitor
Is Asus 4K Gaming 31 inch PQ321Q support Nvidia 3D
or i choose the Asus VG278H 3D monitor
if the 4K monitor support 3D emitter from nvidia then i will choose it but i need answer on that please ?
Ty guys so much
Edited by godfather2009 - 26 Dec 2013 at 4:55am
The Godfather
  Quote fstcvc Quote  Post ReplyReply bullet Posted: 26 Dec 2013 at 7:57am
The specs given on ASUS's website lead me to believe that the 4K display is NOT 3D compatible... ASUS PQ321Q
Unless you're running 4x SLI you probably don't need that big of a PSU but if so, I'd recommend the SilverStone model over the EVGA - better overall ratings & reliability... A better option might be the Corsair Pro Platinum AX1200i.
  Quote godfather2009 Quote  Post ReplyReply bullet Posted: 26 Dec 2013 at 12:12pm
Ty so much fstcvc
but i will put 4 way sli gtx 780 ti so thats why i need 1500 w power supply
and ty for infor about the 4k display :)
The Godfather
