Some help on my New DS system
Post Date: 2011-03-11
PCP View Drop Down
  Quote PCP Quote  Post ReplyReply bullet Topic: Some help on my New DS system
    Posted: 11 Mar 2011 at 4:36pm
hi guys, I got my new DS system! its HUGE!!! but its great!!! I have few questions please help me out:
1. I have 942 HAF-X case, I requested installed one 200mm additional fan on top of the case. When I run the games, like mafia2, total war...etc the fan speed are stay constant is that normal? Can I increase speed?
2. I am worry about overheating, are that setup enough?
thx guys!
maxyme View Drop Down
  Quote maxyme Quote  Post ReplyReply bullet Posted: 11 Mar 2011 at 4:50pm
The case fans will remain consistent and same with the cpu fan. what changes depending on heat is your graphics card fan which is usually the only one you notice and the loudest. you can download msi afterburner to set a fan profile to make it spin faster as the gpu gets hotter. you should modify it a bit to make the fan go faster when it gets hot but other than that your good. the haf series cases stand for high air flow and you shouldn't have a problem.
Steam:pcmaster160
  Quote justin.kerr Quote  Post ReplyReply bullet Posted: 11 Mar 2011 at 5:12pm
CPU fan will adjust the speed based on the CPU temp, unless they locked it in on 100% in the BIOS, which I doubt they would.
  Quote maxyme Quote  Post ReplyReply bullet Posted: 11 Mar 2011 at 5:28pm
really? i thought it connected to the power supply too. my bad.
Steam:pcmaster160
Kyu View Drop Down
  Quote Kyu Quote  Post ReplyReply bullet Posted: 12 Mar 2011 at 10:45pm
these 2 sentences don't go together very well IMO.
you're fine, the fans are set on cpu temp as justin said, unless manually set to run at a locked speed
which i highly doubt also
Congrats on your new DS system !
Edited by Kyu - 12 Mar 2011 at 10:46pm
  Quote maxyme Quote  Post ReplyReply bullet Posted: 12 Mar 2011 at 10:48pm
No, all the fans are set on high except the cpu fan is by the cpu temp and the gpu fan is set with your fan profile.
Steam:pcmaster160
This page was generated in 4.394531E-02 seconds.
