Some Help with parts
Post Date: 2012-08-03
dranza View Drop Down
  Quote dranza Quote  Post ReplyReply bullet Topic: Some Help with parts
    Posted: 03 Aug 2012 at 5:43pm
I sent my 2 years old DS pc in to DS. They found out I have a busted motherboard and CPU which is a i7-930 and EVGA X58 Classified 3X SLI.
So now I have a few choices and I'm not sure which to go.
I have the choice to replace both the same cpu and motherboard or upgrade (Note: My parts warranty is over so I have to pay for them).
Some of the recommendation they gave are
ASUS P8Z77-V DELUXE (Intel Z77 Chipset) (Higher Overclocks and Unique Wi-Fi Features)
Intel Core i7 2700K 3.50 GHz (Unlocked CPU for Extreme Overclocking) (Quad Core)
Intel Core i7 3770K 3.50 GHz (Unlocked CPU) (Quad Core)
ASUS SABERTOOTH Z77
Intel Core i7 3820 3.6GHz (Turbo Mode up to 3.8GHz) (Quad Core)
Intel Core i7 3930K 3.2GHz (Unlocked CPU for Extreme Overclocking) (Six-Core)
ASUS Rampage IV Extreme X79 (Intel X79 Chipset) (Features USB 3.0 and SATA 6Gb/s)
ASUS Sabertooth X79 (Intel X79 Chipset) (Features USB 3.0 and SATA 6Gb/s)
What I'm considering now is the 3820 with the Rampage IV and adding another stick of ram for quad channel. Any recommendation or help in choosing is appreciated.
Motherboard: EVGA X58 Classified 3X SLI (Intel X58 Chipset) (Requires EATX Compatible Chassis)
Power Supply: 1200W Corsair Pro Gold Series (CMPSU-1200AX) (Dual/Triple/Quad SLI Compatible)
Hard Drive Set 1: Operating System: 1x (500GB Western Digital (16MB Cache) (7200 RPM)
Hard Drive Set 2: Multimedia\Data: 1x (2TB Hitachi/Seagate (7200 RPM) (32MB Cache)
Optical Drive 1: Blu-Ray Player/DVD Player (Play Blu-Ray and Play DVDs)
Video Card(s): 2x SLI Dual (NVIDIA GeForce GTX 480 1.5GB (Includes PhysX Technology) (EVGA Brand)
Extreme Cooling: H20: Stage 6: Sub-Zero LCS Dual Loop: CPU & Dual SLI/CrossFire Video Cards & Chipset
H20 Tube Color: Blue Tubing with High-Performance Fluid (UV Lighting Reactive)
CPU Boost: FREE: Stage 1: Overclock the processor between 3.3GHz to 3.9GHz (Cooling Upgrade Recommended)
  Quote bprat22 Quote  Post ReplyReply bullet Posted: 03 Aug 2012 at 6:25pm
My thoughts...... If this is primarily a gaming rig go with Z77 Sabertooth and i7-3770k.    If you video edit alot or render or use Photoshop then the x79 Sabertooth for its quad channel ram and the 3820 cpu.      The 3930 , 6 core chip is for more intense editing, etc.       Hope this helps.    Good luck.
