Sound Card / Media Player Issue
Post Date: 2009-06-26
kwasley View Drop Down
  Quote kwasley Quote  Post ReplyReply bullet Topic: Sound Card / Media Player Issue
    Posted: 26 Jun 2009 at 8:00am
New to the forums but recently bought a DS computer (specs below) and have been experiencing a sound issue. Randy from DS helped me bc one issue was the dongle for the Razor Barracuda sound card was loose and we also re-seeded the sound card.
I am still experiencing issues and usually the sound issues occur after I get this windows error...
Problem signature:
Problem Event Name:     APPCRASH
Application Name:     wmplayer.exe
Application Version:     11.0.6002.18005
Application Timestamp:     49e022ea
Fault Module Name:     wmp.dll
Fault Module Version:     11.0.6002.18005
Fault Module Timestamp:     49e038ac
Exception Code:     c0000005
Exception Offset:     003e9144
OS Version:     6.0.6002.2.2.0.768.3
Locale ID:     1033
Additional Information 1:     fd00
Additional Information 2:     ea6f5fe8924aaa756324d57f87834160
Additional Information 3:     fd00
Additional Information 4:     ea6f5fe8924aaa756324d57f87834160
Read our privacy statement:
http://go.microsoft.com/fwlink/?linkid=50163&clcid=0x0409
Can anyone help with this issue. I do not even have windows media player open but when it crashes then I have no sound or very limited sound. All i do is restart the computer and sound is back up.
Hopefully someone knows about this issue or Randy can help. Here are my specs...
System Memory: 6GB DDR3 1333MHz Mushkin (Highly Recommended) (Digital Storm Certified)
Card Reader: - No Thanks
Hard Drive Set 1: Operating System: 1x (120GB Solid State (By: OCZ) Vertex Series (Model: OCZSSD2-1VTX120G)
Video Card(s): 1x NVIDIA GeForce GTX 285 1GB (Includes PhysX Technology)
Liquid Color: - Not Applicable, I do not have a H20: Stage 3 Cooling System Selected
CPU Boost: Stage 1: Overclock the processor between 3.3GHz to 3.9GHz (Requires Air Cooling Upgrade)
Windows OS: Microsoft Windows Vista Home Premium (64-Bit Edition)
Pre-Install Game: - No Thanks
LCD Display: - No Thanks
Thanks in advance.
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 26 Jun 2009 at 2:07pm
looks like your windows media player crashed.
is your windows up to date also?
try the sound card drivers as suggested and see if this is still happening and make sure your windows is up to date.
  Quote kwasley Quote  Post ReplyReply bullet Posted: 05 Jul 2009 at 1:01pm
Thanks for the suggestions but both windows and drivers are up to date. I even reinstalled sound drivers for card.
Any other help would be appreciated.
Grog View Drop Down
  Quote Grog Quote  Post ReplyReply bullet Posted: 05 Jul 2009 at 1:55pm
Go here and see if this helps... http://www.updatexp.com/wmpdll.html
  Quote kwasley Quote  Post ReplyReply bullet Posted: 06 Jul 2009 at 2:30pm
That run prmopt did not work unfortunately. Think it was an XP fix but I have Vista 64
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 07 Jul 2009 at 10:10pm
disable sound card and uninstall sound drivers and see if this is still happening
satsunada View Drop Down
  Quote satsunada Quote  Post ReplyReply bullet Posted: 08 Jul 2009 at 1:12am
Hmm... does it crash during the opening animations for games or just randomly? Cause wmplayer.exe shouldn't even be open otherwise... unless that's something my XP self doesn't know about Vista.
  Quote kwasley Quote  Post ReplyReply bullet Posted: 08 Jul 2009 at 8:08am
The wmp does not crash during game play. Usually it crashes when no applications are running including wmp and I am afk from the computer.
I can also open wmp and play music with no issue prior to it crashing but once it does crash... I have no sound.
I will try the sound card idea but not sure how to get on board sound to work?
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 08 Jul 2009 at 12:19pm
not asking you to use on-board, just trying to see if we remove the sound card and its drivers from the equation, the problem still happens or not.
also try reinstall wmp and see if that helps.
  Quote kwasley Quote  Post ReplyReply bullet Posted: 08 Jul 2009 at 12:26pm
I would try to re-install WMP but how do you accomplish this? I thought it was baked into windows?
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 08 Jul 2009 at 1:02pm
You know what I thought like xp you could just install it but I see its not the same with vista. In media player from its help section choose update and see if it needs any updates.
Edited by DST4ME - 08 Jul 2009 at 1:02pm
