Sound card question
Post Date: 2010-10-31
Howler View Drop Down
  Quote Howler Quote  Post ReplyReply bullet Topic: Sound card question
    Posted: 31 Oct 2010 at 12:41pm
On my upcoming purchase, i plan to try out the existing sound, then try and put in a new soundcard myself to save some cash. Hopefully it is as easy to do as people say it is. I have 7.1 wireless headphones that use a USB for the connection. Would i need to plug in the heaphones to the new card, or would just using the USB plug in work fine? Then what would be a good choice for the card? Thanks for the help.
