Sound Card
Post Date: 2010-07-11
3Circles View Drop Down
  Quote 3Circles Quote  Post ReplyReply bullet Topic: Sound Card
    Posted: 11 Jul 2010 at 2:32am
I listen to a lot of music, watch movies, and play around with audio editing.  So I'm looking at sound cards.
I plan on using Audioengine A2 speakers.  I already have a pair I use for my mp3 player, and these speakers are fantastic.
I've narrowed it down to two cards:
HT Omega
http://www.newegg.com/Product/Product.aspx?Item=N82E16829271004
--or--
ASUS
http://www.newegg.com/Product/Product.aspx?Item=N82E16829132010
The HT Omega has a PCI connection and the Asus has a Express x1 connection.
Both cards have 64bit win 7 drivers, so that shouldn't be an issue.
Comments?  Other options?
Thanks!
Natsu View Drop Down
  Quote Natsu Quote  Post ReplyReply bullet Posted: 12 Jul 2010 at 12:06am
My friend is using the Asus one with the built in amp. Hes loving it not sure what headset hes using tho.
  Quote !ender_ Quote  Post ReplyReply bullet Posted: 12 Jul 2010 at 12:58am
i dont know enough about sound to advise you either way, but if you havent done it: something i find very helpful while shopping on newegg is to look at the show all reviews page, and i scroll through looking at all the cons to see what the common complaints are when comparing similar items
