Sound card
Post Date: 2014-08-20
koolconjr View Drop Down
  Quote koolconjr Quote  Post ReplyReply bullet Topic: Sound card
    Posted: 20 Aug 2014 at 9:01am
Hello guys I was wondering if the vanquish 2 comes with a sound card because I am thinking about getting astro a40s with the mix amp and the mix amp only works with a sound card. If not would I be able to install a sound card into my vanquish 2? Thanks!!
  Quote ArkansasWoman777 Quote  Post ReplyReply bullet Posted: 20 Aug 2014 at 9:20am
No just onboard sound. Most motherboard these days have an optical thingy which i believe the astro mix amp has and if yours does there would be no need in getting a sound card.
Edited by ArkansasWoman777 - 20 Aug 2014 at 9:20am
  Quote koolconjr Quote  Post ReplyReply bullet Posted: 20 Aug 2014 at 9:43am
Okay thanks! The mix amp does come with an optical cable. I assume that plugs into one of the ports on the back of my computer. Again thanks!
  Quote ArkansasWoman777 Quote  Post ReplyReply bullet Posted: 20 Aug 2014 at 9:55am
If your motherboard has an optical port that is where you plug it in at. If it doesn't then you may need to buy a soundcard but whether or not you can install it i can't tell you.
  Quote bprat22 Quote  Post ReplyReply bullet Posted: 20 Aug 2014 at 10:55am
Like Arkansas said, a lot of motherboards do have an S/PDIF optical out, but the H81m-d motherboard in the Vanquish I don't believe does.   But, it does have a S/PDIF header on the mobo that allows you to plug in a optical module, mount to the back and use that for your TOSLink optical cable.   Not sure the quality but should work.
Meller View Drop Down
  Quote Meller Quote  Post ReplyReply bullet Posted: 25 Aug 2014 at 6:02am
Though it's sound quality won't be as good as a dedicated sound card. You have to typically buy an ROG or higher end (x79, z97, etc..) motherboard to get a good onboard audio. So take all of that into consideration if you're planning on dropping money on a nice head set.
It's like spending $1,000 on a car audio system and playing FM/AM radio on it.
Custom PC
Ryzen 9 5950X
Gigabyte X570 Aorus Xtreme
128GB DDR4 3600mhz
Samsung 980 Pro 512GB m.2
Samsung 960 PRO 2TB m.2 x2
