Sound Cards
Post Date: 2009-08-16
Davis View Drop Down
  Quote Davis Quote  Post ReplyReply bullet Topic: Sound Cards
    Posted: 16 Aug 2009 at 3:12pm
All the games I play are mostly multi-player games,which I talk to my teammates in Ventrilo...I also listen to a lot of music so with that said sound quality is important to me..I have a creative sound card right now which I paid $80 for..I dont care for using the on board sound,never had good luck with those..Should I get a sound card with my system,or should I save the money and  just use the card I have now and install it when my system comes in.
Second part question..If I will install my own card,should I inform DS that I am doing so,so they can leave space for it,is that needed?,does it matter..You want fries with that?Approve
skyR View Drop Down
Digital Storm Apprentice
  Quote skyR Quote  Post ReplyReply bullet Posted: 16 Aug 2009 at 3:36pm
If you have a proper sound system setup ($100+) than a sound card is worth it =p
Well depending on your motherboard PCI layout, there should always be enough room for a sound card if you are getting a single graphics card. However if you are getting SLI, there might not be enough room so it wouldn't hurt to let them know.
Hokinabru View Drop Down
  Quote Hokinabru Quote  Post ReplyReply bullet Posted: 16 Aug 2009 at 3:41pm
If your an Audiophile then yes. :]
  Quote Davis Quote  Post ReplyReply bullet Posted: 16 Aug 2009 at 3:52pm
I use Razor headphones..Dont want what the other guys are saying spilling out into my sons ears,who sits next to me and plays his 360 lol
  Quote Hokinabru Quote  Post ReplyReply bullet Posted: 16 Aug 2009 at 3:56pm
also, soundcards are good for Bass.
  Quote Onkel_Ken Quote  Post ReplyReply bullet Posted: 16 Aug 2009 at 4:48pm
I have the Soundblaster X-fi Fatal1ty version and I love it.  Nice big volume controls on the front of the case and it provides for 3D sound with headphones.  Sound quality is about as good as it could be.  This was a more expensive option than onboard sound but I wanted the best gaming experience that money could buy.  When I play World at War it is total immersion both with outstanding sound and incredible graphics thanks to my Nvidia 295.
Also have a Velociraptor 10,000RPM OS/Game drive makes changing scenes seemless and extremely fast.
You will be happy with all the systems that DS supplies.  The new Extreme prebuilts look great for those that want a hot gaming machine at a reasonable price.  Our go crazy and customize your dream machine to make it special just for you like a lot of us have.
Ermm
Love my computer.
  Quote Davis Quote  Post ReplyReply bullet Posted: 17 Aug 2009 at 1:17am
Ermm
Love my computer.
Do you use headphones or speakers?
If I only use headphones I am not sure that sound card would be right for me?..Or would it?
Roadkill331. View Drop Down
  Quote Roadkill331. Quote  Post ReplyReply bullet Posted: 17 Aug 2009 at 2:03am
For headphones razer's barracuda and hp1 combo are very good.
  Quote Davis Quote  Post ReplyReply bullet Posted: 17 Aug 2009 at 1:25pm
I have owned the Barracudas before.A few other guys on my team own them..They broke though,they are cheaply made..They sound great though..Right now I own the Piranha headset,was thinking of upgrading them when I get my new system..I know sound cards make a difference,but Im not sure on how much a difference they are going to make ya know?
nomec View Drop Down
  Quote nomec Quote  Post ReplyReply bullet Posted: 17 Aug 2009 at 2:52pm
I don't use the "gamer" headsets... they are all gimmicky and the sound quality on the majority of them isn't all that great.  I use a pair of Beyerdynamic DT-770 80ohms cans powered by my Auzentech X-Forte sound card (it has a built in mic-amp) and it sounds INCREDIBLE.
Edited by nomec - 17 Aug 2009 at 2:53pm
QX6850 @ 3.33ghz
Nvidia 680i A1
4gb pc1066 RAM
2x GTX 275s
Vista Home Premium 64-bit
  Quote Davis Quote  Post ReplyReply bullet Posted: 18 Aug 2009 at 1:59am
Things are huge..Where is the mic though?
  Quote nomec Quote  Post ReplyReply bullet Posted: 18 Aug 2009 at 2:31pm
They aren't really big at all... they are meant to cover your whole ear.  There is no mic, since they aren't a headset, just merely higher quality headphones.
For my mic I use a zalman clip-on mic:
It's louder and sounds way better than any built-in mic I've ever used.  Some headsets have decent mics though, but this zalman clip-on is fantastic.
QX6850 @ 3.33ghz
Nvidia 680i A1
4gb pc1066 RAM
2x GTX 275s
  Quote Onkel_Ken Quote  Post ReplyReply bullet Posted: 19 Aug 2009 at 10:48pm
Davis,
I use headphones with my system.  I love how the Fatal1ty sound card allows 3D sound with headphones.  The headphones is actually a headset with a mike for gaming.
I went for this expensive option because of the simple convenience of having knobs for volume & mike on the front console panel as well as connections for RCA plugs on front etc.
A lot of people choose on-board sound, but when you lay out your dream machine you just want what you want.
For example, I got 2 DVDs writers that were exactly the same so that I could switch between the 2 and have the instructions be exactly the same.
Whatever system you pick from Digital Storm you will be happy!  Folks spend a lot of money for minor upgrades that are not really that significant.  Sometimes you just want that 10,000 RPM velociraptor and the top of the line audio card.  I knew at the time I wanted the best video card 295 so I got it.
Now I think people are getting a pair of 275 video cards instead.  This stuff changes day to day.  Just get the system that makes you happy.  The folks on here will help make sure that you don't make a serious mistake.
I didn't go for liquid cooling because I just didn't want the minor hassle of checking levels.  This reduces the max OC some.  I was able to get 3.59 on an air cooled system which was just fine for me.
I hope that you will be happy with your new DS system.
Angry
  Quote Davis Quote  Post ReplyReply bullet Posted: 20 Aug 2009 at 2:02am
Davis,
Angry
A few questions for you if I may.
What headphones do you use?
Did DS overclock your computer for you?
I was thinking of air cooling,but I get worried when the cpu is overclocked..But then again if I have a 5 year warranty,I shouldnt really care.Ouch
