Sound Quality On Avon Laptop
Post Date: 2019-06-16
Zyrius View Drop Down
  Quote Zyrius Quote  Post ReplyReply bullet Topic: Sound Quality On Avon Laptop
    Posted: 16 Jun 2019 at 10:45am
So, I've been looking to purchase a new gaming laptop (my old AW m17x r2 is on its last legs) and so far, the Digital Storm Avon has been the best candidate I've found so far....but there is a concern you may be able to help me with.
I've now read about 6 different reviews for this laptop, all of which address the same issue: the speakers sound terrible. They complained that the volume is too low, that the sound is tinny/echoey and one reviewer stated "this is the worst sound I've heard come from a laptop...any laptop, not even gaming rigs."
Has DS done anything recently to update/resolve this sort of sound quality issue on the Avon platform? Any news or knowledge you guys may have would help immensely.
HockeyBuck View Drop Down
  Quote HockeyBuck Quote  Post ReplyReply bullet Posted: 16 Jun 2019 at 5:38pm
To be quite honest Zyrius, for years now the little speakers on ALL laptops...and most TV's for that matter...they all suck.    It's kind of expected now that most folks will simply hook up good quality larger speakers or an amp and good speakers, or like many gamers...plug in some good headphones to solve that issue.   Its industry wide, and its because as laptops and TV's get thinner, producing quality sound on teeny tiny speakers rarely worked well anyway.
The sound quality source your new Avon laptop or any other AV device can output is a different matter... when connected to a proper set of speakers or headphones that you like.   Look into a good set of powered computer speakers to use with your laptop or a good headset.
  Quote Alex Quote  Post ReplyReply bullet Posted: 16 Jun 2019 at 6:00pm
The Avon does not distort the audio by going very loud, it's not bad... the audio isn't super loud, that's the only feedback some customers may have about the unit.
  Quote Zyrius Quote  Post ReplyReply bullet Posted: 17 Jun 2019 at 6:28am
Trust me when I say that it isn't a HUGE deal or anything, and so far this is still the best laptop based on reviews I've been looking at... I just wanted to know if this has been addressed by DS at all. The "well it's a laptop so speakers always suck, deal with it" sort of approach isn't what I was hoping for...but it is what it is. My poor old Alienware is crazy loud, but granted, it is also considerably thicker. I just like to be able to hear something that is in my lap without needing headphones or extra speakers.
I appreciate the replies.
  Quote Alex Quote  Post ReplyReply bullet Posted: 17 Jun 2019 at 5:18pm
They are quite good... you will be surprised to know. We hope you give us an opportunity to show you.
  Quote Zyrius Quote  Post ReplyReply bullet Posted: 17 Jun 2019 at 5:34pm
I pulled the trigger earlier today. I guess I'll find out in two weeks or so. Thanks again for the replies.
  Quote hoserator Quote  Post ReplyReply bullet Posted: 17 Jun 2019 at 5:57pm
Keep us posted.
  Quote Alex Quote  Post ReplyReply bullet Posted: 17 Jun 2019 at 6:17pm
  Quote Zyrius Quote  Post ReplyReply bullet Posted: 20 Jun 2019 at 5:43am
Alright guys, come on, I'm gonna need you to pick up the pace. Stages 1-6 took THREE DAYS?! THAT'S UNACCEPTABLE! *He says sarcastically and jokingly*
  Quote Cretae Quote  Post ReplyReply bullet Posted: 20 Jun 2019 at 8:07am
  Quote Alex Quote  Post ReplyReply bullet Posted: 20 Jun 2019 at 12:40pm
We're testing the speakers, sorry!
- Just kidding, can't wait for you to get it and let us know how it is for you.
Kurtis916 View Drop Down
  Quote Kurtis916 Quote  Post ReplyReply bullet Posted: 25 Jun 2019 at 5:13pm
Easy fix. upgrade to current windows version 1903 and will automatically download the Sound Blaster Cinema 5 software. After that launch the software, you will immediately get like 10x the volume and still have it clear. u can also remove some of the tinny-ness of them. after that upgrade they are louder then most laptop speakers with average quality.
Digital Storm Avon 17"
i7 9750H
32GB DDR4 2666 dual channel
512GB Samsung 970 Pro M.2 NVMe SSD
NVIDIA RTX 2070
  Quote Zyrius Quote  Post ReplyReply bullet Posted: 25 Jun 2019 at 6:05pm
Awesome, thanks for the tip. I will definitely do so once it arrives :-(
  Quote Kurtis916 Quote  Post ReplyReply bullet Posted: 25 Jun 2019 at 6:44pm
As to the fix for the built in speakers - Update to most recent windows 10 version 1903, it will automatically install the Sound Blaster Cinema 5 software. Open that up, set to music, on eq put +0 bass, +3 treble. on the SBX pro studio settings, set to surround 40, crystalizer to 50, bass to off, smart volume 0, and dialog+ to 0. there you go much better audio! just make sure to launch the software every restart to enable, then you can completely close it and it will save till next reboot.
i7 9750H
NVIDIA RTX 2070
Maclin123 View Drop Down
  Quote Maclin123 Quote  Post ReplyReply bullet Posted: 06 Jul 2019 at 1:51pm
This worked perfectly on my Avon, thank you Kurtis916!
Edited by Maclin123 - 06 Jul 2019 at 1:53pm
  Quote Cretae Quote  Post ReplyReply bullet Posted: 07 Jul 2019 at 3:56am
aronchav View Drop Down
  Quote aronchav Quote  Post ReplyReply bullet Posted: 12 Jul 2019 at 5:34pm
"upgrade to current windows version 1903 and will automatically download the Sound Blaster Cinema 5 software"
How does this work, exactly?
When I got my Avon today, Cinema 5 did not appear to be installed. I did a clean install of Win 10 (just because I like doing that with new computers, not because there was a problem), and it is fully updated and Cinema 5 still does not seem to be installed. I also downloaded the drivers zip file from my DS account page. There is a file in there for Sound Blaster AS (or something like that, it's not called Cinema 5) but I didn't see any executable files in it to install anything. I've looked for Cinema 5 through google and all the download sites look shady, so I didn't try that.
It's not that big of a deal for me because I use headphones, but I'd still like to know why I can't get it.
  Quote hoserator Quote  Post ReplyReply bullet Posted: 12 Jul 2019 at 6:20pm
@aronchav go to your Setting/System/About/Windows specifications and find what version of windows your system is running. If not 1903 go to MS and dl. It will take a few minutes.
Hope this helps.
  Quote aronchav Quote  Post ReplyReply bullet Posted: 12 Jul 2019 at 6:38pm
I'm running Win 10 Pro, version 1903, build 18362.239. I literally just did the clean install and updated everything this evening.
  Quote Zyrius Quote  Post ReplyReply bullet Posted: 12 Jul 2019 at 7:13pm
I will say the sound is still a little low for voice acting in games, but the trick above seemed to help. As for the Sound Blaster bit, make sure you try to manually search for Windows updates, don't just allow it to update in the background. It should spew a list of sound-related downloads once 1903 has been installed. From there, just look for "Sound Blaster Connect" in your Programs list.
NamelessJae View Drop Down
  Quote NamelessJae Quote  Post ReplyReply bullet Posted: 18 Jul 2019 at 6:28pm
Could use some help. I have a Nova laptop and recently reinstalled Windows. Updated Windows but didntget the sound blaster 5 software. My Noa clearly has a POWERED BY SOUND BLASTER 5 sticker on it. Not sure what to do or where to download manually. Could someone point me in the right direction?
Edited by NamelessJae - 18 Jul 2019 at 6:29pm
Making the Internet, one KB at a time.
  Quote Zyrius Quote  Post ReplyReply bullet Posted: 28 Aug 2019 at 7:55am
This is all I got...but this is how I installed it personally on the avon
uumlau View Drop Down
  Quote uumlau Quote  Post ReplyReply bullet Posted: 12 Oct 2019 at 2:43pm
Zyrius is correct. The trick is that after you get the latest windows 10 updates, you have to manually get the FEATURES update. It's not that hard to find once you know you're looking for it. I was in the same boat as you, not seeing a download online and not seeing it on my Avon even though I had the latest Windows 10 1903 update. Doing he FEATURES update did the trick and installed Sound Blaster Cinema 5 software.
This page was generated in 6.738281E-02 seconds.
