Specs for Pre-Built deals
Post Date: 2009-08-17
Hot120 View Drop Down
  Quote Hot120 Quote  Post ReplyReply bullet Topic: Specs for Pre-Built deals
    Posted: 17 Aug 2009 at 4:50pm
Where are the full specs for the pre-built deals?  Below is all that is listed for the Extreme:
$1865.00
Base Specifications:
Overclocked Stable to 3.80GHz
FREE CPU Liquid Cooling
FREE Windows 7 Upgrade
Processor: Intel i7 920 2.66GHz
Memory: 6GB DDR3 1600MHz
Motherboard: EVGA X58M
Graphics: 2x SLI Dual GTX 275
Power Supply: Silent 750W
Storage: 1TB 7200RPM
What is the liquid cooling used?
sjjohns23 View Drop Down
  Quote sjjohns23 Quote  Post ReplyReply bullet Posted: 17 Aug 2009 at 5:37pm
If you click view details under the build and the click customize now from the page that comes up it will go to the build page and show you a complete break down of all components in the system.
The liquid cooling in that particular build is the Asetek LCLC.
  Quote Hot120 Quote  Post ReplyReply bullet Posted: 17 Aug 2009 at 5:42pm
Thanks!
  Quote sjjohns23 Quote  Post ReplyReply bullet Posted: 17 Aug 2009 at 7:02pm
Np
