Speed, Productivity, Moderate Gaming
Post Date: 2013-01-21
Jimmin View Drop Down
  Quote Jimmin Quote  Post ReplyReply bullet Topic: Speed, Productivity, Moderate Gaming
    Posted: 21 Jan 2013 at 10:07pm
I'd like input on the configuration I've chosen for my next Digital Storm PC.
Primary use for this PC will be productivity apps (including very large datasets, Photoshop CS6), moderate gaming (COD: BO2, Skyrim, WoW).
Biggest investment over base machine is the Corsair 480GB SSD.  I have a 120GB SSD in my old rig and the speed of SSD has spoiled me.
I plan to run everything (OS, apps, games, files) off of the SSD.  I have a large library of datasets and I plan to keep the ones I use most often on the SSD and the ones I use less on the hard drive.  I have a 3TB external drive and am religious about backups going there.
For graphics, I don't think I need SLI so not worried about that limitation.  Hoping the config I've chosen is adequate.
Am curious as to whether PSU and my Fan upgrade look good for this.
Optical drive choices seemed very limited to me.  I went with the premium choice offered.
Any input appreciated, as always thanks in advance to the great Digital Storm community.
Ticket Number: 778582
Chassis Model: Special Deal Hot Seller - Corsair Carbide 300R (With Window)
Processor: Intel Core i7 3770K 3.50 GHz (Unlocked CPU) (Quad Core) <b></b>
Motherboard: ASUS P8Z77-V LX (Intel Z77 Chipset) (Does Not Support SLI)
Hard Drive Set 1: Operating System: 1x (480GB Solid State (By: Corsair) (Model: Neutron GTX Series) (SATA 6Gbps) <b></b>
Hard Drive Set 2: Multimedia\Data: 1x (1TB Western Digital Caviar (7200 RPM) (Model: Black Edition) <b></b>
Optical Drive 1: Blu-Ray & DVD Writer/Reader (Burn + Play Blu-Ray & DVDs) (12x BD-R) <b></b>
Video Card: 1x NVIDIA GeForce GTX 660 Ti 2GB (Includes PhysX)
Chassis Airflow: Upgrade All Fans to Corsair Airflow 120mm Performance Edition (Up to 6 Fans) <b></b>
  Quote bprat22 Quote  Post ReplyReply bullet Posted: 22 Jan 2013 at 3:35am
Hi jimmin...   Thats a nice build.
Just another way to go is this config.   The 500r case with its side panel 200mm fan doesn't need the added fans. Better cooling and a nice case.
The X79 Sabertooth motherboard is a quad memory mobo compared to the Z77 dual channel ram.    For CS6 you might find the much wider ram bandwidth helpful for your apps.   The Sabertooth is a quality board with 5 year warranty.
Also with the Hyper 212 air cooler for cpu.    Very reliable and cools very good with a bit less noise. But, the Vortex units have a very good reputation so your call of course.
I can't cut/paste right now so just put in config #.
Config # 778622           Cost $ 2396
  Quote Asangard Quote  Post ReplyReply bullet Posted: 22 Jan 2013 at 4:48am
Here is the config bpratt22 put together so everyone can see it.
Chassis Model: Special Deal Hot Seller - Corsair Carbide 500R (Black Finish)
Hard Drive Set 2: Multimedia\Data: 1x (1TB Western Digital/Seagate/Hitachi/Samsung (7200 RPM) (32MB Cache)
Extreme Cooling: AIR: Stage 1: Cooler Master Hyper 212 EVO (High Performance Cooler)
Edited by Asangard - 22 Jan 2013 at 4:49am
  Quote bprat22 Quote  Post ReplyReply bullet Posted: 22 Jan 2013 at 7:21am
Thanks,   Asangard.  Big%20Smile
  Quote Jimmin Quote  Post ReplyReply bullet Posted: 23 Jan 2013 at 12:16pm
Thanks much, this is especially helpful for me in regard to motherboard, case/chassis, and cooling options.  Thanks again for the help.
  Quote bprat22 Quote  Post ReplyReply bullet Posted: 23 Jan 2013 at 12:43pm
You're welcome.   Need anything, one of us can hopefully help.
