Stage 1 and Stage 2 OC
Post Date: 2009-08-22
Davis View Drop Down
  Quote Davis Quote  Post ReplyReply bullet Topic: Stage 1 and Stage 2 OC
    Posted: 22 Aug 2009 at 12:32am
Is it worth it?..I am leaning towards no its not,but maybe someone can change my mind..
When laying it out in plain numbers its like Stage 1 is  3300 to 3900 and Stage 2 is 4000 to 4200..
Not that huge of a gain for the price difference..
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 22 Aug 2009 at 12:39am
for gaming you won't really notice the difference,specially above 1600 x 1200.
sirsiddius View Drop Down
  Quote sirsiddius Quote  Post ReplyReply bullet Posted: 23 Aug 2009 at 6:41am
http://www.driverheaven.net/reviews.php?reviewid=783&pageid=19
You will definalty notice the diffrence in games between the lowest possbile stage one oc (3.33 ghz) and the highest possible stage 2 oc (4.2 ghz).
Edited by sirsiddius - 23 Aug 2009 at 6:44am
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 23 Aug 2009 at 7:01am
no you will not, notice above 1600 x 1200 the fps makes no difference between the 920 @2.66GHz, 965 @ 3.2Ghz and 965 oced to 3.6GHz:
Tom Clancy's Ghost Recon: Advanced Warfighter 2:
Crysis, notice below the difference betweeen 920 @ 4.0GHz and 920 at 2.66GH is only 3 fps, so between 3.3GHz and 4.0GHz is gonna be even less, but even at 3 fps you won't notice it:
  Quote sirsiddius Quote  Post ReplyReply bullet Posted: 23 Aug 2009 at 7:04am
Again you forgot to attactch you little graphs.
Anyways
1) DST4ME did you even look at the link I provided.
2) If Ocing only nets you 3 fps then why the hell to people OC at all?
Edited by sirsiddius - 23 Aug 2009 at 7:34am
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 23 Aug 2009 at 7:12am
1. Are you seeing the charts posted? every site that has done the real use test has the same results to offer.
above 1600 x 1200 OC does not make much of a difference at all in games, at that point it becomes more of a GPU issue, even with crisis that heavily relies on CPU.
2. people OC so that their PC can do everything else that does matter faster, gaming is only one aspect of owning a PC.
I mean you do see the 920 stock at 2.66GHz pulling only 3 fps less then the 920 oced to 4.0GHz right? one article does not over rule god knows how many differen't site's identical results.
granted at stock a cpu will not do as well at its oced version however between 3.3GHz and 4.0GHz in gameing above 1600 x 1200 you will not notice much of a difference, if any at all.
Edited by DST4ME - 23 Aug 2009 at 7:19am
  Quote sirsiddius Quote  Post ReplyReply bullet Posted: 23 Aug 2009 at 7:23am
Sorry I might not be seeing your charts. Im currently on vacation in China, and the communists are very touchy on what their citizens are allowed to see. So if you hotlinked images to photobucket or imageshack it's very possible that I am not able to see them. Geek
Edited by sirsiddius - 23 Aug 2009 at 7:25am
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 23 Aug 2009 at 7:25am
they are images hosted on imageshak, you can't see them?
Edited by DST4ME - 23 Aug 2009 at 7:25am
  Quote sirsiddius Quote  Post ReplyReply bullet Posted: 23 Aug 2009 at 7:29am
No. private internet is already very patchy (the goverment is very paranoid here) and we had a hurricane last week that tore up 9 undersea cables 4 of which are used by my isp. So if you have pictures in your above post I cannot see then, sorry.
I tried a proxy and I can see the images now, so yeah its my problem. Anyways I leave China on the 29th of aug so I won't have to put up with this for very long.
Edited by sirsiddius - 23 Aug 2009 at 7:37am
