Stage 2 and Stage 3??? Hai :)
Post Date: 2014-04-02
AshesDen View Drop Down
  Quote AshesDen Quote  Post ReplyReply bullet Topic: Stage 2 and Stage 3??? Hai :)
    Posted: 02 Apr 2014 at 6:40pm
Well just wanted to check what you guys had to say about this. Stage 2 is basically getting all the parts for your computer correct? Well I got the stage 2 and stage 3 email at the SAME time. So it seems like they would have to assemble the computer to install operating system and demos in stage 3? I may be wrong, but I hope they didn't shoot my parts like free throws into my Bin !!! Just wondering if its like this for everyone. But its going very fast too. Its stage 3, and its only been 3 hours It says 9-14, but I hope sooner than later, but obviously dont want them to rush at all...
Can't Wait to get my New Computer!
Specs:
Intel i7-4770k
NVIDIA GTX 770 2GB SuperClocked
Digital Storm 120mm Radiator
  Quote ArkansasWoman777 Quote  Post ReplyReply bullet Posted: 02 Apr 2014 at 8:04pm
Yes stage 2 is the gathering of parts, here is what each stage means:
Stage 1: (Payment Processed)
Your order has been successfully processed. Our accounting department is now preparing your build sheet and passing this over to our inventory control department so we may allocate the components necessary for your order.
Stage 2: (Inventory Assignment)
A special component bin has been assigned for your order. We then locate components from our inventory and place them inside your component bin. If any components are out of stock, we are then waiting for them to be delivered to our storage center. Once all of the hardware is inside your component bin, it is then placed in queue for phase 1 stress-testing.
Stage 3: (Phase 1 Stress Testing)
Your order is now placed into one of our specialized test benches. The installation of the operating system, drivers and any applications that are specific to the system you ordered are completed here. Our Digital Storm Integration Engineer will also install any demos, benchmark utilities, and burn-in software necessary to correctly monitor your systems performance throughout our burn-in process. Afterwards, we perform a series of grueling tests that push the hardware components in your system to the very limit. This Stage is especially important because it is here where the system either excels or fails. If it does fail, our Digital Storm technicians will identify any problems and replace them before we ship your computer system. If the computer system still does not pass our tests, we will then re-build it with a new batch of components.
Stage 4: (Engineering Lab)
Your order has successfully passed our phase 1 stress testing, it has now progressed into our engineering lab. A specialized Digital Storm Assembly Engineer will carefully put together your order as if it was their own. They have a passion to build every system as if it was their show piece.
Stage 5: (Phase 2 Stress Testing)
Your order has been passed to our final phase 2 stress-testing team. They run a final batch of tests to verify the integrity and stability of your system. This allows us to ensure that every system we ship will be a rock solid machine for years to come.
Stage 6: (Quality Assurance)
Your system is undergoing a very detailed quality control analysis. A Digital Storm Quality Inspector is tasked with inspecting your machine for missing screws, loose cards, checking for special requests, verifying the configuration, and double checking our stress-test results. Our inspectors are trained with an eye for detail and ensure that every system leaves our facility with the art of perfection.
  Quote fstcvc Quote  Post ReplyReply bullet Posted: 02 Apr 2014 at 11:41pm
Many parts are pre-tested before being installed into your machine so sometimes parts gathering, part stress testing and assembly can go by really fast. Normally the Phase 2 stress testing is where the wait is as this is the stress test of all the components combined (phase 1 is normally the parts individually tested).
  Quote AshesDen Quote  Post ReplyReply bullet Posted: 03 Apr 2014 at 4:53pm
So it wen't through stage 4 and 5 already :D And Its been less than 24 hours. I'm excited, yet a little scared. Are they really doing "Quality Testing" and stuff? I'd rather wait a little longer and have it working when it arrives... But its suppose to be 9 - 14 days, and its at stage 5 in less than 24 hours. Is it really going to stay on 1 Stage for 9 or 10 days? Just a bit odd. How long did these stages take for you!?
Like I said, hope they aren't shooting free through's with my parts
Specs:
Intel i7-4770k
  Quote ArkansasWoman777 Quote  Post ReplyReply bullet Posted: 03 Apr 2014 at 5:00pm
It varies for everyone i have the stages listed in my sig, trust me Digital Storm does quality testing and everything.
  Quote AshesDen Quote  Post ReplyReply bullet Posted: 03 Apr 2014 at 5:05pm
Yea yours took 7 days :P Mine is at the same stage and its only been less that 24 hours. I believe this is a good company, but I just hope they aren't RUSHING it :)
Specs:
Intel i7-4770k
  Quote ArkansasWoman777 Quote  Post ReplyReply bullet Posted: 03 Apr 2014 at 5:15pm
It usually doesn't take all that long if its a simple build. Also mine didn't take 7 days, did you look at the dates or just the stages?
  Quote AshesDen Quote  Post ReplyReply bullet Posted: 03 Apr 2014 at 5:56pm
I mean total lol. Yours took 7 days! Mine is at the last stage in 24 hours? Not complaining, but just wondering :)
Specs:
Intel i7-4770k
surf71zx View Drop Down
  Quote surf71zx Quote  Post ReplyReply bullet Posted: 04 Apr 2014 at 4:19am
Your unit could of been a prebuilt one and thats why its passing stages so fast.
  Quote AshesDen Quote  Post ReplyReply bullet Posted: 04 Apr 2014 at 5:09am
Well yea, but I changed the Motherboard, GPU, CPU, PSU, and RAM.
Specs:
Intel i7-4770k
  Quote ArkansasWoman777 Quote  Post ReplyReply bullet Posted: 04 Apr 2014 at 5:19am
Like i said earlier every persons build will vary, some will be quicker ,some will take longer depending if there are parts that are backordered or if a part was a bad batch. You can always call them or email Alex and ask how things are going.
  Quote AshesDen Quote  Post ReplyReply bullet Posted: 04 Apr 2014 at 5:33am
ok, thanks
Specs:
Intel i7-4770k
  Quote ArkansasWoman777 Quote  Post ReplyReply bullet Posted: 04 Apr 2014 at 5:41am
Originally posted by AshesDen
ok, thanks
You're welcome
UffDa View Drop Down
  Quote UffDa Quote  Post ReplyReply bullet Posted: 04 Apr 2014 at 8:12am
I think it would be cool if they took a pic of the rig in each stage and sent it to the owner of the order. It's silly and a little overhead, but right now while my rig is at Stage 5 it would be cool to see a pic of it on the workbench doing burn in.
It's totally not necessary, but it would be cool nonetheless!
  Quote ArkansasWoman777 Quote  Post ReplyReply bullet Posted: 04 Apr 2014 at 8:28am
Well now they do take pictures and you can ask to see pictures of it upon request.
Email Alex at [email protected] and ask if he can send you a picture
Edited by ArkansasWoman777 - 04 Apr 2014 at 8:30am
  Quote UffDa Quote  Post ReplyReply bullet Posted: 04 Apr 2014 at 8:38am
I will do that! Although, I admit, I hate to bug them...but I've been sharing updates with my kids and they are excited too.
  Quote ArkansasWoman777 Quote  Post ReplyReply bullet Posted: 04 Apr 2014 at 8:54am
You're not going to bug them
  Quote surf71zx Quote  Post ReplyReply bullet Posted: 04 Apr 2014 at 10:02am
I think they only take pictures of high end exotic builds. If they took a picture of every unit coming down the line they would be overwhelmed.
  Quote ArkansasWoman777 Quote  Post ReplyReply bullet Posted: 04 Apr 2014 at 10:08am
I think they take pictures when it hits stage 6 right before it leaves the facility. Because i've seen Alex post pictures of peoples builds if it arrived damaged or whatever.
Edited by ArkansasWoman777 - 04 Apr 2014 at 10:13am
  Quote UffDa Quote  Post ReplyReply bullet Posted: 04 Apr 2014 at 10:25am
That would make sense. mine is in Stage5, so it's like a couple days away from that [Stage5 includes 72hr burnin right?]
  Quote ArkansasWoman777 Quote  Post ReplyReply bullet Posted: 04 Apr 2014 at 10:28am
I have the stages listed in my sig, but it usually varies for each build
  Quote Alex Quote  Post ReplyReply bullet Posted: 04 Apr 2014 at 2:33pm
I see the excitement here. Can't wait to see what you think about the unit when you get it.
  Quote AshesDen Quote  Post ReplyReply bullet Posted: 04 Apr 2014 at 2:51pm
Yea Well its on Stage 6 now. How long does Quality Testing usually take? And should I be worried it only took 30+ hours to do soo? lol
And how long does ground shipping take
Specs:
Intel i7-4770k
  Quote bprat22 Quote  Post ReplyReply bullet Posted: 04 Apr 2014 at 2:55pm
Ground shipping is 5 business days, coast to coast. Depends where you live.
  Quote UffDa Quote  Post ReplyReply bullet Posted: 04 Apr 2014 at 3:00pm
We need to move my State closer to California!!!
  Quote AshesDen Quote  Post ReplyReply bullet Posted: 04 Apr 2014 at 3:02pm
Coast to Coast??? WOW! I live in Nebraska, so it would only take a few days? In that case I could actually have my Computer by my birthday (April 10th). Not likely, but just maybe :) If it doesnt take 3 days to ship to NE, how long do you think it would take?
Specs:
Intel i7-4770k
  Quote AshesDen Quote  Post ReplyReply bullet Posted: 04 Apr 2014 at 3:03pm
and i'm technically a verified customer :P how do I get that under my Profile? or does it have to arrive first.
Specs:
Intel i7-4770k
  Quote bprat22 Quote  Post ReplyReply bullet Posted: 04 Apr 2014 at 3:03pm
UffDa... That was my exact thought when mine shipped.
Edited by bprat22 - 04 Apr 2014 at 3:05pm
  Quote UffDa Quote  Post ReplyReply bullet Posted: 04 Apr 2014 at 3:06pm
I used the same e-mail for the forum that I used in placing the order. The forum confirmed it (or the admin behind the scene did)
  Quote bprat22 Quote  Post ReplyReply bullet Posted: 04 Apr 2014 at 3:08pm
To get Verified Customer the email you used to order and the one for the forums has to match, exactly. Case sensitive,etc.
DS can fix it if any problems.
  Quote ArkansasWoman777 Quote  Post ReplyReply bullet Posted: 04 Apr 2014 at 3:09pm
Bprat beat me to the answer
Also Ashes no you should not be worried that it took 30 or so hours, like i mentioned stages vary from build to build
Edited by ArkansasWoman777 - 04 Apr 2014 at 3:10pm
  Quote AshesDen Quote  Post ReplyReply bullet Posted: 04 Apr 2014 at 3:09pm
Yo, im not using the same email I used to buy it (paypal) can you just like confirm me alex? Lol
Specs:
Intel i7-4770k
  Quote UffDa Quote  Post ReplyReply bullet Posted: 04 Apr 2014 at 3:11pm
Yeah, it's been 7 years to the month since I built my last gaming rig...
Core2 Duo - E6600
EVGA 8800GTX
2GB RAM
160GB RaptorX (10,000 RPM)
500GB WD Caviar (7,200 RPM)
Antec Nine-Hundred
Sound Blaster XFi-Fatal1ty
It was hell on wheels back then...but this new one will top that one. I've been dying to play some awesome games these last few years and that time is coming soon.
  Quote AshesDen Quote  Post ReplyReply bullet Posted: 04 Apr 2014 at 3:19pm
YEA my current is a 5 year old HP Touchsmart XD Its somewhat hard to edit with After Effects on this thing. Sometimes it crashes, other times it lags when I put a 300+ fps clip in there. And time remapping is just horrible :P Cant wait for this one! ITS GANNA BE LIGHTNING FAST :D :D
Specs:
Intel i7-4770k
  Quote Alex Quote  Post ReplyReply bullet Posted: 04 Apr 2014 at 3:23pm
Sorry can't!
This page was generated in 0.1210938 seconds.
