Stage 3 Air cooling
Post Date: 2008-02-24
Bubbalotski View Drop Down
  Quote Bubbalotski Quote  Post ReplyReply bullet Topic: Stage 3 Air cooling
    Posted: 24 Feb 2008 at 1:06am
What is Stage 3 and what is the difference between that and stage 2 (the configuration page explanation has not been updated yet)?
How many of the Scythe fans are in the 850 case in the Stage 3 cooling?
How much louder (if at all) is the stage 3 over the stage 2?
If you're in a fair fight, you didn't plan it properly.
- Nick Lappos, Chief R&D Pilot, Sikorsky Aircraft
  Quote Bubbalotski Quote  Post ReplyReply bullet Posted: 25 Feb 2008 at 7:21pm
Anybody?
Bill the Cat View Drop Down
Forum Bitch!
  Quote Bill the Cat Quote  Post ReplyReply bullet Posted: 25 Feb 2008 at 8:26pm
I guess the people who know are pretty busy. I used to know, but I'm obsolete.
SunfighterLC View Drop Down
  Quote SunfighterLC Quote  Post ReplyReply bullet Posted: 25 Feb 2008 at 8:32pm
yea im actually pretty curious about this myself. ive been pondering about maybe when i get mine to upgrade from stage 2 to 3. But im not sure, i mean if its just improved case fans, i might be able to do that myself.
Glenn-HI View Drop Down
  Quote Glenn-HI Quote  Post ReplyReply bullet Posted: 25 Feb 2008 at 10:52pm
I just ordered my computer today and elected for stage 3 cooling. I am not positive but the difference between stage two and three is they replace the case fans that would come with your computer with scythe fans. These fans are usually quieter and push more air than the standard cheap fans most cases come with.
Kelly View Drop Down
  Quote Kelly Quote  Post ReplyReply bullet Posted: 27 Feb 2008 at 5:03pm
exactly Glenn.  If you order stage 3, I think we fill up the systems with as many of the fans as we can.  Some cases (like the Stacker 830) handle more than others, but we make sure to give you the best performance that we can.  Sometimes that includes case mods.
Dashuu View Drop Down
Guest
Guest
  Quote Dashuu Quote  Post ReplyReply bullet Posted: 27 Feb 2008 at 5:34pm
We also upgrade all of the fans to Scythe S-FLEX fans.
1
