Stage 3 cooling?
Post Date: 2008-08-29
Bero View Drop Down
  Quote Bero Quote  Post ReplyReply bullet Topic: Stage 3 cooling?
    Posted: 29 Aug 2008 at 11:06am
How loud is Stage 3 cooling?
TomD View Drop Down
  Quote TomD Quote  Post ReplyReply bullet Posted: 29 Aug 2008 at 11:22am
Bero,
Alot depends on which case you select and how many fans it has. Also, what you are going to be using the computer for, and your tolerance for background noise.
On my 950 case I would describe it best as about the equivalent of a small space heater or bathroom fan. They use Zalman fans which are fairly quiet and make much less noise than most stock fans, but the accumulation of the case, videocard, CPU, motherboard, memory, and power supply fans adds up. My system has 9 fans running.
If you are irritated by background noise, or use the CPU for recording/sound applications it will probably drive you crazy. I use my machine mostly for games and the speakers drown out the noise anyway, so I hardly notice it.
It you want to keep things quiet, you might want to consider liquid cooling instead. There are also sound deadening materials available to line the inside of the case that can help keep the noise level down.
  Quote Alex Quote  Post ReplyReply bullet Posted: 29 Aug 2008 at 1:31pm
Great reply!
Bero View Drop Down
  Quote Bero Quote  Post ReplyReply bullet Posted: 29 Aug 2008 at 3:44pm
I would mostly be using it for gaming. This is the config that i was thinking about using stage 3 for. Also let me know if it would be better to use liquid cooling. Im trying to save alittle money lol (Been saving for this best for like year and half)
Chassis: Cooler Master Cosmos S Edition
Processor: Intel Core 2 Quad QX9770 Extreme 3.20GHz (1600MHz FSB) (12MB Cache)
System Memory: 4GB DDR3 OCZ at 1600MHz Platinum Edition
Card Reader: - No Thanks
Hard Drive 1: 32GB Solid State (By: OCZ) (Ultimate Lightning Speed)
Raid Option: - No Thanks
Hard Drive 3: - No Thanks
Video Card: 2x SLI Dual (NVIDIA GeForce GTX 280 1GB)
TV Tuner: - No Thanks
Extreme Cooling: Air Cooled Stage 3 WindTunnel (Copper Heatpipe Heatsink & Additional Case Fans)
Modifications: LCD Temperature Display & Fan Controller
Boost Video Card: Yes, Overclock the video card(s) as much as possible with complete stability
Windows OS: Microsoft Windows Vista Home Premium
Protection: - No Thanks
LCD Display: - No Thanks
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 29 Aug 2008 at 3:52pm
Liquid cooling will get you much higher/stable results then fans ;)
valtek View Drop Down
  Quote valtek Quote  Post ReplyReply bullet Posted: 29 Aug 2008 at 4:52pm
I'd look into if this HD is too small to use as a boot drive. Basic Vista install is 18 gb. That leaves you with less then 50% of the HD free. I seem to remember reading somewhere at one time that anytime more then half of your boot drive is full things can slow down.
Edited by valtek - 29 Aug 2008 at 4:53pm
q9550/750 psu
ati 4870/rampage 48x
4gb corsair 800mz
