Stage 7 - Heat question
Post Date: 2009-08-24
Mozzman View Drop Down
  Quote Mozzman Quote  Post ReplyReply bullet Topic: Stage 7 - Heat question
    Posted: 24 Aug 2009 at 6:42pm
My rig entered Stage 7 today and below are the QA test results.  Do you think the idle temperature  is a little high?  Rig does have two SLI 275 graphic cards which may be partially responsible.  The computer will be in a room that gets a little warm in the summer.  Is there reason for concern here?
Thanks to all that reply.
Stage 7: (QA Passed)
Your order has successfully passed our stringent quality assurance process. Everything from top to bottom on your purchase has been verified by an experienced Digital Storm technician.
Testing Details By: xxxxx
Processor Temperatures
Idle: 43C
Overnight Load: 81C
Important Notice: Overclocked systems will definitely run hotter than stock units. Your unit has been tested to be fully stable in our stress-test facility at these temperatures.
Overclocked Processor Settings
Processor Speed GHz: 3.6
CPU Multiplier: 20
Voltage CPU VCore: 1.375
VDroop Control: Yes
i7 - BCLK MHz: 172
i7 - Voltage QPI\DRAM: auto
i7 - Voltage QPI\PLL: auto
i7 - Voltage CPU VTT: 175
i7 - Voltage IOH Vcore: auto
i7 - Voltage ICH Vcore: auto
i7 - Voltage IOH/ICH I/O: auto
i7 - PWM Frequency: 800
780i/790i - Memory Clock Mode:
780i/790i - CPU FSB MHz:
780i/790i - Voltage FSB:
780i/790i - Voltage SPP:
780i/790i - Voltage MCP:
Motherboard BIOS: SZ2F
Video Card Driver: 190.38
Chipset Driver: CD
Sound Card Driver: CD
  Quote Alex Quote  Post ReplyReply bullet Posted: 24 Aug 2009 at 6:49pm
Those are perfectly fine temperatures. Especially since your processor is overclocked to 3.6GHz. Don't forget, that's when your process is under complete 100% stress, which you won't be running at on a regular basis anyways.
Dsnewb210 View Drop Down
  Quote Dsnewb210 Quote  Post ReplyReply bullet Posted: 24 Aug 2009 at 6:50pm
It seems ok to me, the overnight load is most likely the prime 95 results. Prime 95 can heat up some of the best liquid cooled setups.
I
950SI
965/4.0 Frostbite LC
6GB Dominator 1600mhz
Rampage II Extreme
Intel 160 320 Raid 0
GTX 285 SLI
Dell 2408wfp/2407wfp
Logitech G19, Razer Mamba
Wireless Astro A40's
Bose Companion 5 Speakers
  Quote Mozzman Quote  Post ReplyReply bullet Posted: 24 Aug 2009 at 6:51pm
Thanks for the reply Alex.  That is good to hear!  Now I will wait for the "beast" to arrive!
  Quote Onkel_Ken Quote  Post ReplyReply bullet Posted: 24 Aug 2009 at 11:21pm
3.6 OC is sweet!!!  I have 3.59 and really enjoy the OC on my beast!
