Stuck at low-resolution
Post Date: 2009-05-27
JFuller092 View Drop Down
  Quote JFuller092 Quote  Post ReplyReply bullet Topic: Stuck at low-resolution
    Posted: 27 May 2009 at 3:49pm
I upgraded a friends computer from XP to vista and im stuck at a really low resolution, it wont let me change it, the computer doesnt have a video card, and only has two options for its resolution, but i cant select the higher one, any recommendations other than buying a video card.
Intel I7 940 @ 4.0
Asus P6T X58 Mobo
12GB OCZ Flex DDR3 2000mhz
3x EVGA SSC edition GTX285
Thermaltake Spedo Advance
2x GSkill 128gb SSD Hardrives and a 1TB Western digital
Power+Cooling 1200W PSU
Zurginator View Drop Down
  Quote Zurginator Quote  Post ReplyReply bullet Posted: 27 May 2009 at 4:13pm
Update your drivers?
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 27 May 2009 at 5:59pm
that is a typo right? the pc does have a gpu? I'm assuming the answer is yes then tell me the brand and model of the gpu
  Quote Zurginator Quote  Post ReplyReply bullet Posted: 27 May 2009 at 6:00pm
It might not have a card. On-board video isn't a card. :P
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 27 May 2009 at 6:06pm
well on board video might just have those 2 options due to lack of driver support for vista, not sure, but at the end its a driver issue like you said.
  Quote JFuller092 Quote  Post ReplyReply bullet Posted: 29 May 2009 at 3:43pm
Well it says that intel R graphics driver is installed, but it doesnt allow me to select a higher resolution.
And yes, its onboard video.
Intel I7 940 @ 4.0
Asus P6T X58 Mobo
