Sub-Zero Cooling (2011 Socket)
Post Date: 2010-08-03
mfronz View Drop Down
  Quote mfronz Quote  Post ReplyReply bullet Topic: Sub-Zero Cooling (2011 Socket)
    Posted: 03 Aug 2010 at 2:45pm
I am thinking about investing in a high end rig within the next month and Im curious if the chip/mounting geometry for new wave of intel cpu's will be substantially different than the 1366. If so, is it worth it to configure a LC system for the 1366 and hope the same setup will work for the 2011 socket?
Also, does anyone think the 8 to 10 core SB chips be worth the wait or is the 980x a solid investment right now? At the moment cost is not much of an issue.
  Quote justin.kerr Quote  Post ReplyReply bullet Posted: 03 Aug 2010 at 3:09pm
if cost is not an issue, get the 980x now, enjoy it, wait for them to get the bugs worked out of SB, should take a year, maybe 2 lol, then upgrade to it.
the LC.. you will have to change the water block, everything else will work for either 1366 and 2011
ablahblah View Drop Down
  Quote ablahblah Quote  Post ReplyReply bullet Posted: 03 Aug 2010 at 3:21pm
Intel i think released info that 1366 heatsinks will be compatible with 2011 CPUs..not sure though.
R4D4RPR00F
Core i7 920 @ 3.9Ghz
Asus Sabertooth X58
EVGA GTX 570
Mushkin 6GB 1414Mhz
Rivenloch View Drop Down
  Quote Rivenloch Quote  Post ReplyReply bullet Posted: 03 Aug 2010 at 6:28pm
I didn't even know what a 2011 socket was until reading this, but when I wiki'd it, I found this:
"This socket is expected to be released alongside Sandy Bridge-EX in Q3 2011, and will support 4 memory channels as well as 40 PCIe 3.0 lanes [1]; the socket will measure 58.5mm x 51mm, and is backwards compatible with LGA 1366 cooling solutions [2]."
Citation leads here: http://vr-zone.com/articles/a-look-into-intel-s-next-gen-enthusiast-platform--sandy-bridge-e--waimea-bay/8877-1.html
