suggestion on fan placement
Post Date: 2009-07-26
titusmckieus View Drop Down
  Quote titusmckieus Quote  Post ReplyReply bullet Topic: suggestion on fan placement
    Posted: 26 Jul 2009 at 10:20am
I upgraded my PSU and Graphic cards and am running  SLI.
 I had a 120mm fan that I had previously installed in the area located at the bottom of the case. Now with the larger power supply I had to remove the fan.   It Will  not  physically fit any more.
As I was looking for a place to move it to I noticed that the holes on the fan line up with the holes in the front knock outs just above the hard drives and below the optical drive.
The question I have is that if I move that fan there will it mess up the air flow in the case.
Here is some pictures of what I'm talking about
I have the fan just loose here so you can see where it would go
This is the knock outs . the fan will be on the inside
Right now i just have one extra exhaust fan on the top of the case
Here is my set up
Edited by titusmckieus - 26 Jul 2009 at 10:22am
Landaulet View Drop Down
  Quote Landaulet Quote  Post ReplyReply bullet Posted: 26 Jul 2009 at 8:51pm
As long as you face the fan the right way
Depends if your trying to blow in air, or take it out.
  Quote titusmckieus Quote  Post ReplyReply bullet Posted: 26 Jul 2009 at 9:03pm
Well right now the two top fans exhaust.
 the rear fan exhaust
the large side fan intakes
and the front lower fan intakes
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 26 Jul 2009 at 10:41pm
it does not matter much which way its blowing.
  Quote titusmckieus Quote  Post ReplyReply bullet Posted: 26 Jul 2009 at 11:54pm
suppose i'll try it blowing in first.
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 26 Jul 2009 at 11:58pm
others have done it here, if I'm remembering correctly the difference was maybe 1c to 2c.
  Quote titusmckieus Quote  Post ReplyReply bullet Posted: 27 Jul 2009 at 12:12am
Pffff.  Not really worth the extra noise for 1-2 c but the fan LED would look nice there.
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 27 Jul 2009 at 12:34am
sorry I meant the difference of having it blow in or out, how much difference the fan itself will make no matter which way its faced, I'm not sure about, more airflow is always welcomed
