Svchost Help
Post Date: 2009-05-17
  Quote DST4ME Quote  Post ReplyReply bullet Topic: Svchost Help
    Posted: 17 May 2009 at 4:27pm
HM install Prio after install in task manager under processes you can put the mouse on each process and see what that svchost is running
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 17 May 2009 at 4:39pm
My pleasure HM good luck, most likey lot of services/drivers are running those but its good to check.
Edited by DST4ME - 17 May 2009 at 4:40pm
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 17 May 2009 at 5:30pm
yes lol
EdH63 View Drop Down
  Quote EdH63 Quote  Post ReplyReply bullet Posted: 17 May 2009 at 5:46pm
I have 13 of these running on mine.  I dl'd the program and it looks as if all of them are hosts to Windows programs of some sort or another.  How do you know, if any, which programs to end or not?  Also, why are most in green and some in red?  I noticed that my Linksys is in red, so is the Prio program, but most are green.
Edited by EdH63 - 17 May 2009 at 5:47pm
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 17 May 2009 at 8:45pm
the red ones have no digital signature so prio can't identify it
  Quote EdH63 Quote  Post ReplyReply bullet Posted: 17 May 2009 at 9:29pm
Thanks, DST4ME.  Should I be ending any of these?
  Quote DST4ME Quote  Post ReplyReply bullet Posted: 17 May 2009 at 11:04pm
honestly not sure what they are, you would know best, you can make your number of processes lower by editing your startup list from ccleaner's startup section.
