System Beeping
Post Date: 2009-06-12
Chase_Lambeth View Drop Down
  Quote Chase_Lambeth Quote  Post ReplyReply bullet Topic: System Beeping
    Posted: 12 Jun 2009 at 11:22pm
What would cause my system to beep, and have to be turned off/restarted for it to stop.. It just happens out of random.. and I'm looking at the temp, and everything seems good..? It just start out of nowhere to beep beep beep ect.. Can I unplug the thing making the noise or will that cause damage to the computer..?
Zurginator View Drop Down
  Quote Zurginator Quote  Post ReplyReply bullet Posted: 12 Jun 2009 at 11:55pm
It's probably your mobo speaker. But it would only beep if something is changing/wrong.
  Quote Chase_Lambeth Quote  Post ReplyReply bullet Posted: 13 Jun 2009 at 12:00am
yeah I know its the mobo speaker.. but I cant seem to find anything wrong when it happens.. the computer is sitll working fine when its going off..
can it hurt if I take it out?
  Quote Chase_Lambeth Quote  Post ReplyReply bullet Posted: 13 Jun 2009 at 8:48am
Everytime it is about to happen, my side fan light dems, and then the fan slows down.. and then on the front panel the DAN RPM light and little toggle thingy goes off and then the fan goes off, and it starts beeping.. But I dont know what would care this..
Bill the Cat View Drop Down
Forum Bitch!
  Quote Bill the Cat Quote  Post ReplyReply bullet Posted: 13 Jun 2009 at 4:37pm
It might also just be an alarm that the case fan is crapping out. I had an issue like that with one of my DSO boxes. Just had to replace the fan.
[email protected] View Drop Down
  Quote phil@fostini.com Quote  Post ReplyReply bullet Posted: 13 Jun 2009 at 5:44pm
Have you added any cards to the MB?  I have seen that my MB would beep for no reason because of some issues with some cards. But I agree with all above there could be many reasons. The fans  are a good indicator the PS is going bad or something is taking up a hellava lot of power. If you have your configuration handy maybe someone here can spot something.
Fusion - clean energy
  Quote Chase_Lambeth Quote  Post ReplyReply bullet Posted: 13 Jun 2009 at 10:40pm
I havent installed anything new, and the system runs fine.. Ive just unplugged that fan and no more beeping!
